[Home] - [HELP] - [Forums] - [Articles] - [Photo Gallery] - [Groups] - [Chat] - [Classified Ads] - [Subscribe] - [Links] - [Books] - [Sponsors] - [eBay Tools]
How To Create Exhaust Smoke Rings
this thread has 13 replies and has been viewed 6029 times
Old 03-29-2009, 03:38:12 AM
cham cham is offline
Default How To Create Exhaust Smoke Rings
I've seen some of the larger engines set up to make some incredible smoke rings from the exhaust pipe.
Can this be done with a smaller 1 1/2 hp H&M engine?
Old 03-29-2009, 04:29:17 AM
Ray Cardoza's Avatar
Ray Cardoza Ray Cardoza is offline
Default Re: How To Create Exhaust Smoke Rings
I think it could be done but most that i have seen are throttle governed type making the smoke rings.
Old 03-29-2009, 04:38:38 AM
johnny-farmall johnny-farmall is offline
ive got a piece of 3inch pipe about 3 ft long on my fairbanks that makes killer smokerings, i believe its got to do with the length more than o.d.
The Following User Says Thank You to johnny-farmall For This Post:
Old 03-29-2009, 08:01:58 AM
Rich Hudak Rich Hudak is offline
A vertical pipe with a 90 degree end. decent size o.d. Give the engine a lttle more oil via the cylinder oiler. I had a 4" on my 10hp Z. made perfect smoke rings about 10 - 12" in diameter and would put about 15 in the air at once on a calm day. Its a thing of beauty.
The Following 3 Users Say Thank You to Rich Hudak For This Post:
Old 03-29-2009, 08:49:26 AM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
I have a 2hp engine that blows them. The pipe was fabricated by the previous owner. What was done is to take a 2" diameter section of exhaust pipe about 20" long and modify one end so that it can be threaded to a pipe fitting. On the other end, the last 4 inches are flared out larger to about 2 1/2" diameter. I always thought the flare out was what made the rings. As the engine runs and draws the exhaust air in/ou/in/out, the smoke is trapped inside the exhaust pipe. Having a larger diameter at the end keeps some smoke trapped along the outer walls while the exhaust blows through the center and you have a rolling effect with the air inside the last 4 inches. That's my theory on it anyways.
The Following 2 Users Say Thank You to Jebaroni For This Post:
Old 03-29-2009, 08:56:45 AM
midpw midpw is offline
My 7 UA Thermoil blows nice smoke rings once it is nice and warmed up. I've never quite understood why.........
It's a simple 2 1/2 inch vertical pipe about 30" tall from the head. Sure is pretty when the sun is at the right angle.
Old 03-29-2009, 09:37:45 AM
I think it's best to have a larger pipe on the exhaust to act as a collector for the smoke, when the engine fires it "punches through the smoke", rolling it up the walls of the pipe forming a ring. If you look closely at the smoke rings they area actually rolling, like taking an o ring and rolling it over a shaft. I want to try a piece of square tubing and see if I can make smoke squares.
The Following User Says Thank You to J.B. Castagnos For This Post:
Old 03-29-2009, 09:49:40 AM
Marc P Marc P is offline
We have had pretty good luck with smaller engines also, but the throttle govern are the best at it. The best we found was mixing tranny fluid with the gas like a 2 cycle mix. Great smoke rings. The bigger pipes do make larger rings but we've used about 2" dia and it was fine, a couple of feet or so long does well. Play around and find what you like. We have even used 3" stove pipe before and it is successful.
The Following User Says Thank You to Marc P For This Post:
Old 03-29-2009, 01:02:56 PM
IronCity2006's Avatar
IronCity2006 IronCity2006 is offline
Location: Hoopeston, Illinois (90 miles south of Chicago)
My 1.5 herculies can make some nice smoke rings. I just use a 1 3/4 exaust pipe.
When the world looks saine, you have went insaine.......................
The Following User Says Thank You to IronCity2006 For This Post:
Old 03-30-2009, 06:54:36 AM
Rick I Rick I is offline
Here's a video of my 2HP Taylor H&M engine blowing smoke rings:
http://www.youtube.com/watch?v=7jT4Ga3QLTE&fmt=18
I was surprised at the speed of the ring as it rises, and how well it holds together.
I used 2 feet of straight 2.5" dia exhaust pipe, a reducer that fit inside, etc. Closeup photo is at http://www.oldengine.org/members/inz...flerdetail.JPG
The Taylor requires oil mixed with the gas anyway (1/4 pint per gallon), so this comes naturally when I have this straight 'stack on.
-Rick
The Following 2 Users Say Thank You to Rick I For This Post:
Old 04-02-2009, 01:55:02 AM
Thanks for the help. I didn't think it would be that easy
Gotta try it cause I can stop tinkering!
I may beat you to it (K)
Old 04-02-2009, 02:28:14 AM
Hey Rich,
You indicated a 90 degree bend on your exhaust pipe.
Is this 90 degree - the typical bend at the head to get the pipe pointed upward, or something different at the exhaust tip?
Cham
Old 04-04-2009, 06:22:08 PM
Actually my 10 hp z had an elbow on the bottom of the head and a second 90 that aimed the exhaust pipe up. The exhaust was 2" out of the head, after the 2 90s, I used a swedge to neck it up to 4".
Old 04-04-2009, 08:25:55 PM
Dick Graybill's Avatar
Dick Graybill Dick Graybill is online now
I saw one with a drip oiler piped into exhaust pipe to let oil into hot exhaust .It worked and didn't foul sparkplug.
Diesel exhaust smoke Gunny Onan Generators 4 08-16-2007 09:35:35 PM
how to make smoke rings john w ridings Antique Engine Archives 1 05-08-2004 07:27:58 PM
Making smoke rings NormS Antique Engine Archives 3 03-04-2003 12:42:25 AM
Engine smoke rings Tanner Remillard Antique Engine Archives 6 04-10-2002 07:15:55 PM
Blow smoke, shoot flames, and exhaust gas! Fairbanks_Kid Antique Engine Archives 44 12-23-2001 10:24:28 AM
