Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Garden Tractors / Mowers / Scooters
Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
Briggs model A won't run
Here is a link to my 1946 locke and the problem im having getting it to run. Any help would be...
this thread has 6 replies and has been viewed 807 times
Old 05-26-2012, 08:00 PM
eric67m eric67m is offline
Default Briggs model A won't run
Here is a link to my 1946 locke and the problem im having getting it to run. Any help would be appreciated.
http://www.mytractorforum.com/showth...96#post2169096
Old 07-29-2012, 08:38 AM
Arlie Levy Arlie Levy is offline
Default Re: Briggs model A won't run
Set spark plug gap at .015. That might help.
Old 08-01-2012, 09:38 PM
I have since pulled the engine and it is sitting in my garage. I did a capetown test and found my rings are leaking and it would need a head gasket also.
I think that the lack of compression is why the plug was dry. It was not pulling fuel thru the carb.
If I ever play with it later I will also try tightening up the plug gap.
Old 08-01-2012, 11:39 PM
Road Torpedo Road Torpedo is offline
That would be a fuel restriction.
Compression has to be extreemly low that it would not pull in any fuel. And i mean well below anything as low as 20 P.S.I
And even THEN, you'll still pull a little fuel.
Old 08-02-2012, 10:46 AM
Bruce Dorsi Bruce Dorsi is offline
What is a "capetown test?"
Old 08-02-2012, 09:37 PM
A "capetown" test would be auto correct for leak down test.
My leak down showed 35% loss at 100 psi. It would not even fire with starting fluid with the carb removed.
Old 08-03-2012, 12:15 AM
There is a hidden mechanical trouble then. And thats were good diagnosis comes in.
But your not loosing any great preasures to need to be severly alarmed. You do have worn rings but...BUT, these were not high compression engines eaither and running your valves in on worn rings tends to compound trouble that may have not existed before.
Briggs & Stratton Model 6 (model N) army DAF Small Air Cooled Gasoline Engines 5 11-04-2010 07:27 AM
Help with: Briggs and Stratton Model A and Model BR6 skochko Small Air Cooled Gasoline Engines 4 05-12-2010 12:59 AM
Briggs Model PB Crank (For Moto-Mower Detroit Model) Jonathan Widelo Small Air Cooled Gasoline Engines 0 02-05-2009 01:43 PM
Briggs engine model W series and Y model Travis Small Air Cooled Gasoline Engines 1 02-01-2009 07:58 PM
New guys needs help with Briggs model Z and model KR IHfan Small Air Cooled Gasoline Engines 7 06-16-2008 08:43 AM
