Witte color?
I have two Witte's one headless one later head type. Heed to know the proper color,colors. Thank...
this thread has 3 replies and has been viewed 1623 times
Old 12-07-2004, 10:37 AM
Jerry Willis Jerry Willis is offline
Default Witte color?
I have two Witte's one headless one later head type. Heed to know the proper color,colors. Thank you. Jerry Willis
Old 12-08-2004, 08:46 AM
David M. Lyon's Avatar
David M. Lyon David M. Lyon is offline
Default Re: Witte color?
Wendell's notebook says DuPont #5204 Acrylic enamel...However! Most DuPont automotive paint retailers are getting out of the CENTARI mixing business in favor of the more popular NASON synthetic enamel, or their basecoat/clearcoat systems...(NASON is the most inexpensive) I havn't tried to put clearcoat on an engine yet, Not sure just how it would look!....The closest thing I have found in a rattle can, is Rustoleum Hunter Green...Not the DARK hunter green!
David M.
Old 12-08-2004, 09:23 AM
Images: 305
You will find that Krylon Hunter Green is a closer match than Rustoleum, but Krylon doesn't hold up to gasoline too well. It's OK if you are careful about spills. Buy a can and test it out. If it dries a long time, it holds up better.
Actually, I find it hard to understand why Rustoleum doesn't make a deep dark red or green for us antique restorers. Not enough demand I guess. They are heavily into light shades of pink and purple for furniture painters.
Another choice is to have a gallon mixed up at Sherwin-Williams and brush it on. This isn't as bad as you'd think and given the right temperature, it should flow on fine. Your color choice may shift between wet and dry.
http://old-engine.com/witte.htm
Old 12-08-2004, 11:09 AM
Jason N Jason N is offline
I use four parts Rustoleum Hunter Green and one Part Black. Makes a nice dark brewster green color.
Witte Color ?? Chuck Weimer Antique Gas Engine Discussion 0 05-23-2006 08:43 PM
Witte color red or green? SteveK Antique Gas Engine Discussion 0 09-29-2005 08:20 PM
Witte paint color Jerry Willis Paint Shop 1 12-07-2004 07:09 PM
Color code for Witte model H Chris Kirk Antique Engine Archives 0 06-30-2003 08:04 PM
Witte color Jim McDermott Antique Engine Archives 3 04-30-2002 10:31 PM
