Welding Shop
#42 Marquette welding electrodes
Hi All, I found a small stash of these rods at my Grand dad's.According to the box they are for...
this thread has 2 replies and has been viewed 945 times
Closed Thread
Old 08-07-2003, 04:52 PM
Rob Charles
Default #42 Marquette welding electrodes
Hi All, I found a small stash of these rods at my Grand dad's.According to the box they are for welding cast iron.All they say is preheat is nessecary.What they are is around a 3/16" round actual cast iron rod with flux on it.There is a bare spot in the middle for holder in the stinger on the arc welder so I guess you use both ends to the middle.I haven't had a chance to try them so I was wondering if anyone has used them and are they any good?Thanks Rob
Old 08-07-2003, 08:24 PM
Darryl Boyd
Default Re: #42 Marquette welding electrodes
Hi Rob, Boy I haven't seen that type of rod in over 20 years, and then I think they were old then. The section in the middle where the flux is missing is indeed for the stinger to clamp on. I was told they did this because the cast iron (or filler rod) was high resistance and to shorten the rod by grabbing it in the middle, in effect lowered the resistance. This would make the way the rod welded more consistant.
Then you used the other end.
I guess better than making two short rods???
You might want to cook them in an oven for a little while. That will remove any moisture in the flux.
DB
Old 08-08-2003, 12:48 AM
Not only that, Marquette always made top quality stuff!!!! Craig
Closed Thread
Old Marquette generator/car starter tima Kohler Generators 3 11-21-2008 07:55 PM
Looking for cast iron electrodes... JBoogie Stationary Steam & Traction Engines 51 07-11-2007 08:54 PM
Marquette 220 Welder johnny45 Welding Shop 2 12-06-2006 08:20 AM
Marquette Welder - Generator Rod Jones Welding Shop 1 06-10-2002 09:50 PM
Marquette welder/generator Joseph Turrisi Welding Shop 0 08-23-2001 09:47 PM
