Stover ct-2 diagram
I am very new to this.i just bought a ct2 in pieces.most I can figure out where goes by images...
this thread has 10 replies and has been viewed 890 times
Old 01-15-2012, 08:20 PM
paultyrer paultyrer is offline
Default Stover ct-2 diagram
I am very new to this.i just bought a ct2 in pieces.most I can figure out where goes by images google.however I am desperate need for a parts view diagram.can anyone tell me how to get one.
Thanks in advance.
Paul
Old 01-16-2012, 11:56 AM
Exclamation Re: Stover ct-2 diagram
Try looking up Hit & Miss Enterprises parts web site. He has blown up drawings of most of the engines he sells parts for, as well as owners manuals. I am pretty sure the CT is amongst them!
Old 01-16-2012, 12:29 PM
Walt Beeman's Avatar
Walt Beeman Walt Beeman is offline
Default Re: Stover ct-2 diagram
Big Goomba has recently logged his restoration here,
http://www.smokstak.com/forum/showthread.php?t=91735
He may have additional photos from his project that might help you. I have a hit and miss CT-2 but have never seen any assembly drawings for them. There are hit and miss and throttle governed CT-2 models, do you know which you have?
Keep Enjoying Old Iron,
Walt Beeman
Old 01-16-2012, 01:22 PM
Thanks for the info. I have a list pending for Hit Miss.
I need to know where the baffle / shield on the inside of the crankcase goes. Has a 90. bend with 2 holes in it. Also has a area which is open. I believe this goes over the cam gear, but need to know if it goes under the small weight gear (between block and weight gear ) or ontop of the weightgear between bolts and weight gear (which is how i have it)
Picture attached.
Paul
Old 01-17-2012, 06:50 AM
John Savot John Savot is offline
It goes on top - not under like your picture. John
Old 01-17-2012, 07:51 AM
Spannerboy Spannerboy is offline
Hello there, here are some pics I took recently as I stripped down aCT2. Hopefully they help. Make sure you have the oil feed chute in place that goes under the two gears. Have taken somePics of the exhaust push rod & timing gear if you need it let me Know. Cheers Graeme.
The Following User Says Thank You to Spannerboy:
Old 01-17-2012, 10:01 AM
Thank you.if I put on top.theshield then stops the pin pushing out.i must be missing something.thanks.i will take another look
Old 01-17-2012, 10:49 AM
Bend the sheild a little so it is 90 degrees, if that doesn't work file a little notch so it clears. John
Old 01-17-2012, 05:59 PM
I did put the shield under the bolt and ontop of the idler bracket for the weight cam. I did have to bend it more though to get it to clear the push rod.
Now question if i may, can you post the pictures of the push rod close up on the outside of the block. Mine is a HIt Miss not a governed engine, these would help me out a lot.
Thank you once again.
Old 01-17-2012, 06:28 PM
BigGoomba's Avatar
BigGoomba BigGoomba is offline
I just finished up working on a CT-2 but I just sold it to help offset the money I put into a another engine. I have been in and out of it a number of times so might be able to answer some questions.
Dont have any photos of the pushrod that I can think of. I can poke around and see what I can find.
-Steve J
9 and counting
Old 01-17-2012, 06:41 PM
These are some pics I took with flywheel still on. There is a small flat steel plate with a U shaped cutout at one end that acts as a pivot between governor shaft & the latching mechanism. the u end hooks under the nut on the gov shaft & pivots on a small rounded shaft under the round side cover.
Big Goomba its a shame you had to sell that CT2 did you get it running allright. Nice pickup for someone after all the work you put in!
IHC 3hp M diagram ? Gold Dredger Guy Antique Gas Engine Discussion 0 10-11-2009 08:36 PM
Parts Diagram for a Vertical YB Stover Farmall Antique Gas Engine Discussion 3 09-13-2007 03:09 PM
Need Parts Diagram for 1905 Vertical Stover Paul Maples Antique Gas Engine Discussion 2 11-16-2006 08:24 AM
Hit and miss diagram Jeff Schmidt Antique Engine Archives 1 03-23-2004 09:11 PM
3ph converter diagram Al Levora Generators & Motors General Discussion 7 01-31-2004 04:46 PM
