MEP002A Genset No ac power
this thread has 5 replies and has been viewed 1548 times
Old 01-16-2012, 11:59:24 AM
DieselDan84 DieselDan84 is offline
Exclamation MEP002A Genset No ac power
I recently bought a MEP002A genset and rebuilt the injector pump and got it running. It runs great and had AC power a week ago i fired it up yesterday and now i have no AC Voltage?? Any one have any suggestions???
Thanks, Dan
Old 01-16-2012, 09:27:47 PM
CDS32 CDS32 is offline
Default Re: MEP002A Genset No ac power
How long did you hold the start switch after the unit fired up? Have you started the unit at half throttle previoudly or at idle?
Old 01-16-2012, 09:58:59 PM
coyote62ny coyote62ny is offline
first and for most never start any mep series gen set at idle or run at idle or anything other than 60 hertz that said. start the gen set and hold the start switch in the start position for no more that 10 seconds this should energize the gen head and you should get power if not you need to read the tms and do some trouble shooting if energizing it doesnt work and you have idled the engine for more than a couple of seconds you most likly have a bad transistor in the vr the tms will give you test prosedures for testing the vr hope this helps
Old 01-17-2012, 10:04:52 PM
Ok, Thanks guys. I live in PA and its been cold and had to hold the start switch probly longer then 10seconds. When held longer then 10 seconds what dose it do? and where can i pick up a vm manual?
Thanks, Dan
Old 01-17-2012, 10:47:53 PM
USCGMatt USCGMatt is offline
Holding it in start not only starts it but flashes the field. If you hold it for more than 10-15 sec. you can burn up the excitation circut. About how long did you crank? Oh and Steelsoldiers has all of the manuals. Good luck.
I count to 10 as i'm cranking then release, if its cold sometimes it takes 3 attempts to stay running.
Old 01-18-2012, 12:29:34 PM
Richard L Richard L is offline
I can e mail you the complete set of manuals, you can apply 12 volts to the exciter field to see if it is the VR or the Diodes in the field. I can send that specific page, if you like.
I have found the best thing to do if it is the regulator to modify and update the unit to a new Flight Systems regulator,that has underspeed protection, and can be rebuilt .
The military Vr are aging and the parts are getting weak from old age
R
mvamaunet@gmail.com
MEP002a Genset Injector pump parts DieselDan84 Military MEP and Aircraft Gen-Sets 3 12-28-2011 04:57:42 PM
MEP002A power problem steeler Military MEP and Aircraft Gen-Sets 6 12-06-2011 09:00:07 AM
30 EC genset no build up of power brucemetz Onan Generators 2 04-25-2009 09:27:40 AM
OK, The Power Is Out And Your Genset Is Up And Running, Robert in W. Mi. Generators & Motors General Discussion 19 10-31-2006 07:50:05 AM
Wisconsin TH with US Light Power 5.5kw genset Shootist357 Generators & Motors General Discussion 9 01-01-2006 04:48:28 AM
