Is this a Kingston 4 ball carburetor?
this thread has 8 replies and has been viewed 3077 times
Old 01-16-2012, 10:29:22 PM
Jim Sherman's Avatar
Images: 84
Photo Is this a Kingston 4 ball carburetor?
Is this what is called a 4 ball carburetor? It's all brass and I think it may have been off from a Model T.
Thanks in advance.
Old 01-16-2012, 11:09:31 PM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Default Re: Is this a Kingston 4 ball carburetor?
You are correct sir. Pull the 4 plugs on top and there should be a ball in each port. Model T was one of its applications.
Patrick
The Following User Says Thank You to Nevr-Enuf-Stuf For This Post:
Old 01-17-2012, 12:16:26 AM
ehpower2 ehpower2 is offline
maybe a stupid question but what do the balls do
The Following User Says Thank You to ehpower2 For This Post:
Old 01-17-2012, 10:41:05 AM
http://www.oldmarineengine.com/discu.../3433/804.html
Patrick
The Following 3 Users Say Thank You to Nevr-Enuf-Stuf For This Post:
Old 01-20-2012, 02:04:18 PM
Skip Anderson Skip Anderson is offline
Location: Bloomington/Aitkin, MN, and Prescott, AZ. winters hopefully
It is a Kingston 4-ball carb, but it may not be for a Model T. What is the center to center dimension between the holes on the mounting flange? Your carb looks quite large in the photo.
Kingston made many different sizes of carbs depending on the application. If yours is a Ford model, it is a 1913-1914 Kingston 4400 Model Y carb. Nice carb!
Old 01-20-2012, 04:36:51 PM
John Hamilton's Avatar
John Hamilton John Hamilton is offline
That little brass tag on the side should tell you the model. As noted, the T used the model Y carb.
Old 01-22-2012, 11:59:24 PM
Images: 84
The center to center measurement is 2-1/8" on the mounting holes.
All that's on the brass tag is "Kingston" Patent Applied for.
Thanks,
Jim
Old 01-23-2012, 12:53:45 AM
macdonald macdonald is offline
the meadowbank engine i am restoring also has a 4 ball kingston
Old 01-24-2012, 01:59:26 PM
Jim,
2-1/8" C-C is correct for a T. The opening should be about 1-1/16". I have two five ball carbs that measure 2-11/16" C-C and they are way to large for a T. They also had a larger opening (they were probably off a stationary engine). Nice carb, and thanks for the response.
Calling all Kingston Carburetor Experts 60case Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 24 09-09-2011 09:56:36 PM
Briggs B - Kingston Carburetor Kit ken702 Small Air Cooled Gasoline Engines 1 03-31-2011 09:04:07 PM
Kingston Carburetor for Case 12-25 Richard Sturdy Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 02-16-2011 05:08:37 AM
Kingston carburetor ID Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 11-05-2009 10:45:56 PM
Kingston Carburetor Rebuild Bryan Storey Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 10-05-2009 06:27:26 PM
