New Engine Trailer
I am going to buy a new covered trailer for engine shows. The pickup beds are running upwards of...
this thread has 4 replies and has been viewed 908 times
Closed Thread
Old 08-10-2003, 07:06 PM
Jeff Conner
Default New Engine Trailer
I am going to buy a new covered trailer for engine shows. The pickup beds are running upwards of 36" high making loading more difficult and the load is open to the elements. I tend to research everything to death before I buy so instead, I was hoping to get a consensus from more experienced trailer owners. 12' floor length should be fine for me. Questions remain like, single or dual axle, type of tie downs, ramps or drop down door, etc. I would appreciate knowing what has worked well and what hasn't. I limit myself to 4hp and smaller engines. I would appreciate any feedback or suggestions. Thanks.
Old 08-10-2003, 08:12 PM
Kevin Hesse
Default Re: New Engine Trailer
Tandems ride better I think. Also if I were to do it over I would get one with the pointed front, big help in wind resistance. Also E-track on the floor like semi trailers use with movable hold downs makes tieing down the engines easy. And like building a garage, what ever size you get you'll wish it was bigger. Kevin
Old 08-10-2003, 09:10 PM
David Reichert
Rubber torsion type springs ride lot better than the leaf kind. If you arent going far or fast the wedge front may not be worth the cost or loss of useable space. Chip guard on the front will save the front of the trailer from dings and scraches from rocks thrown up by tow vehicle. Look at the floor structure, some have the "joists" closer together than others and that makes the floor a lot more solid. Some have better grade of plywood in floor also. If you buy new you can order what you want.
Old 08-11-2003, 10:58 PM
Kris Meddock
I have been towing all kinds of trailers for years , both tandem and single and i have built a few along the way but the single thing that has helped me the most is a load leveling hitch. it will level out a toungue heavy load and help keep the trailer from swaying and most of all....the trailer cant come unhitched !!!!!!
Old 08-12-2003, 02:07 AM
I trailered for years without a load leveling hitch. Boy, what a difference. I agree with Kris, don't leave home without a load leveling hitch, and a dual axel trailer with brakes. Paul , getting ready for "BREAK" on third shift in Pa.
Closed Thread
Engine Trailer - overhead I beam Tilinghast Trucks, Trailers and Hauling for Shows 8 07-01-2009 04:58 PM
Trailer for steam engine Dan Dyman Stationary Steam & Traction Engines 18 03-18-2008 01:25 PM
Engine Direction on Show Trailer Jim Gorter Oil Field Engines 20 09-27-2006 07:32 PM
A frame Engine trailer at Wauseon curt dewitt Stationary Steam & Traction Engines 15 07-11-2006 09:43 PM
Engine Trailer Mike Antique Engine Archives 11 01-05-2003 01:52 AM
