3phase /2okw generator AVR circuit diagram
this thread has 1 replies and has been viewed 8527 times
Old 01-26-2012, 03:22:15 AM
M.Khaleel M.Khaleel is offline
Default 3phase /2okw generator AVR circuit diagram
I have a 3phase/20kw AC generator with( kirloskar 3piston air cooled engine) booster/transformer controlled voltage regulator. I want update with electronic automatic voltage regulator(AVR), so please provide me circuit diagram for AVR to build myself.
Old 01-26-2012, 06:32:37 AM
armandh armandh is offline
Default Re: 3phase /2okw generator AVR circuit diagram
your current sensing inductor type regulator is likely as good as any you can build. [if the speed is correct and steady]
no voltage regulation will work well if the speed is not well governed !!!
there are inexpensive aftermarket modern regulators
for example
http://www.partsfortechs.com/asapcar...648-p-153.html
but if you just want to experiment use a regulated DC supply bucked down by an unregulated DC supply to control the field.
the experimental part is finding the right proportions for these voltages, and controlling the larger current to the field.
PS we might reinvent the wheel while we are at it.
PPS use all necessary precaution as lethal voltages will be present !!!
Need circuit board or wiring diagram for hol-gar 19180 1 phase 3 wire 240v sisgar Military MEP and Aircraft Gen-Sets 2 08-03-2009 11:40:00 PM
4.0UR Circuit Diagram Needed Abe Onan Generators 6 03-01-2006 03:38:57 PM
300C859, or equal,circuit diagram John Weatherley Onan Generators 2 01-02-2006 12:26:45 PM
Kohler 800 Circuit Diagram Ed Stoller Kohler Generators 0 09-06-2004 02:17:34 PM
3phase generator? Dennis Generators & Motors General Discussion 7 10-08-2001 10:18:36 PM
