Onan 6.5NHE-1r/26100A wont fire up
this thread has 5 replies and has been viewed 1652 times
Old 01-29-2012, 08:29:00 PM
samloopy87 samloopy87 is offline
Default Onan 6.5NHE-1r/26100A wont fire up
6.5NHE-1R/26100A
C860831180
emrald 3
im a bit confused as to what to look at atm also a wireing diagram and such might help me
dead stick when start button is pressed no 12+ to coil /fuel system etc
when jumpered to 12+ it will run but genset does nothing
it seems maybe the boards not functioning it came with a 30A fuse installed in it but shows no signs of buring visable on inspection
is this unit able to be ran without a board?
---------- Post added at 06:29 PM ---------- Previous post was at 06:26 PM ----------
samloopy87@hotmail.com for any larger mails
Old 01-29-2012, 08:53:29 PM
Default Re: 6.5NHE-1r/26100A wont fire up
Service manual for spec. A, should be in your in-box.
The Following 2 Users Say Thank You to Max Thompson For This Post:
Old 01-29-2012, 09:17:52 PM
TY kindly ..im betting ill get a lot further now! the mystry box has a manual now lol
Old 01-30-2012, 01:57:59 PM
grr the plot thickens today it has decided it doesnt want to fire up even if i jumper 12+ to the coil B+ post popped a time or 2 but sparks verry intermittant at best
Old 01-30-2012, 02:44:23 PM
bobbyz72 bobbyz72 is offline
Your points are bad . replace points or upgrade to electronic ignition.
Old 01-30-2012, 09:15:11 PM
Originally Posted by bobbyz72 View Post
Your points are bad . .
Yes, your points could be bad. You may also have something grounding them out. The service manual, a test light, & a VOM will save a lot of guess work, throwing parts at these things can get expensive & produce poor results.
Onan 2.8 kv-fa/26100a wont stay running seeverest Onan Generators 39 05-02-2014 02:19:25 PM
homelite lots or spark wont fire? brian leonew Chain Saw Collectors 9 01-31-2012 05:00:47 AM
John Deere STX38 wont fire up pjlamon Garden Tractors / Mowers / Scooters 3 06-22-2011 09:41:07 PM
Kohler 5E wont fire jayjr Kohler Generators 3 05-31-2011 09:40:06 AM
Onan 6.5NHE Wont stay running when you let off of the start switch. kikid Onan Generators 7 05-20-2010 12:00:15 PM
