Onan BGEF no ac current
this thread has 3 replies and has been viewed 1677 times
Old 02-05-2012, 11:30:46 AM
steve440 steve440 is offline
Default Onan BGEF no ac current
I have a Onan 4000 genset, 4BGEFA26101F. When running, I am not getting any ac current. I've used a volt meter behind the control panel on the terminal block and tested for voltage off of L1, and L2. Nothing. Now what? Help! I could also use a service manual, if anyone out there has one. Thanks, Steve.
Old 02-05-2012, 11:59:42 AM
Default Re: Onan BGEF no ac current
http://www.cumminsonan.com/www/pdf/manuals/965-0528.pdf
The above link "Should" get you the BGE manual to cover your spec. F unit. This should give you a place to start. The trouble shooting sections will give you step by step instruction. When you get stuck, the "Smart Guys" around here will pick up where the manual left off.
You will likley want to pull the cover off the gen-end & check the brushes & ALL connections. The spade terminals tend to get brittle on these units.
The Following 3 Users Say Thank You to Max Thompson For This Post:
Old 02-05-2012, 01:48:35 PM
Gunny Gunny is offline
No current or no voltage?
Old 02-05-2012, 02:53:19 PM
Nope, nothing at all off of L1 orL2.
Onan Field Current Question flagmaster Onan Generators 15 04-17-2011 02:16:42 PM
Onan MDJE Over Current Protection? FLracer Onan Generators 5 06-03-2010 04:46:05 PM
ONAN 5GO Reverse Current Relay TomFG Onan Generators 14 03-11-2010 12:09:04 AM
Onan Corp. Alternating Current Synchronous Brushless Generator Model: 88-22040 Ben Clarke Onan Generators 0 01-25-2010 09:47:29 PM
Onan BGEF runs 230 volts when its a 120 volt unit. transambandit77 Onan Generators 3 04-07-2008 03:18:27 PM
