| Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps, washers and antiquities of the industrial revolution. |
Wooden corn sheller projectI was given an antique wooden cornsheller to fix up by a guy my dad knows. Well after inspection I...this thread has 16 replies and has been viewed 2041 times
I was given an antique wooden cornsheller to fix up by a guy my dad knows. Well after inspection I determined its all there, just all 4 legs are in need of replacement I need to replace the top and make a new bottom to direct the kernals into a bucket. I have found some traces of blue paint on the side panels and some very faint pinstripeing. I would like to know if anyone knows how old this is and who made it,
Thanks alot http://www.youtube.com/watch?v=1ZGUdOnw7lI |
Good luck with it, you did a good job of the basic analysis that it would be good if you do an "After" one. Looking forward to that.
The Following User Says Thank You to Pat Barrett:
I don't know what kind it is, but its got to be around 100 years old. Generally, wooden shellers were built before 1920, when steel shellers started appearing. Try not to replace any more wood than you have to. When you put new wood in an old wooden machine, you seem to take some originality and nostalgia out of it, more so than with a steel machine. If possible, try not to paint the old wood. Just put some preservative on it. I have an old wooden sheller that is a family heirloom. It has faded pinstriping and writing, but that adds to the nostalgia!
The Following User Says Thank You to Rick Gilder:
41Briggs,
I think your sheller might have been made by A.B. Farquhar of York PA. They were large builder of farm machinery from the late 1800's through the 1950's with a full line of equipment including steam engines, early gas tractors, sawmills, etc. They were bought out by Oliver in the 50's. I think you might have a model called the Eclipse but I have to do some checking to be sure. |
The Following User Says Thank You to Scott Hartz:
---------- Post added at 05:30 PM ---------- Previous post was at 05:25 PM ---------- Quote:
I would say that you most likely have a Tiffin corn sheller. If you do a Google image search, you'll find that the colors seem to line up as well as the castings for the bearings, and the flywheel (which was common to several brands).
The Following User Says Thank You to Jebaroni:
here is my tiffin
when i started on it finished not correct but i did it the way i wanted you can see all of my info i could find for mine here http://rolke.dyndns.org/ftp/corn%20sheller/ |
The Following User Says Thank You to 41Briggs:
Unless I'm seeing it wrong, it looks like the 4 main posts extend beyond the top board. That's unusual and so is the casting at the cob discharge hole. A rear discharge Tiffin would usually have the flat cast piece surrounding about 3/4's of the hole. You can see that in the picture of the previous posting.
Are there any casting numbers on it? A Tiffin hopper should have a "U" on it. I think a Keystone had "N" and then a number. Can't remember what Farquhar numbers were. |
Here's a picture of a hopper from a 1-hole Keystone "Invincible". The casting number is N17.
I would guess your sheller is from the Keystone Farm Machine Co., York, Pa. The problem is according to a 1908 Farm Implement News buyers Guide, the following one-hole shellers were made by Keystone. Burrall, Clinton, Clipper, Codorus, Cumberland Valley, Dixie, Eagle, Economy, Imperial, Invincible, Noxall, Our Baby, Reliance, Southern, Susquehanna, and Tiger. Burrall, Clinton, CV, Economy and Invincible can be ruled out. I've not seen a Keystone with the screen, but it's not out of the question that the screen on your sheller may be original. Other Pennsylvania manufacturers had the screen to discharge the corn to the flywheel side. |
I have an old Dains corn sheller and it is not in the best of condition. Some of the paint could flake off very easily. Does anyone know of a way of preserving the paint as it is without being detrimental to the value of the sheller? I was thinking of something like clear spray acrylic paint as an example. Thanks
cchopper,
Try using the paint additive Penetrol. It will do a good job of rejuvinating the paint that is left and help keep it from flaking off. Clean off as much dirt as you can first than apply the penetrol just as it comes out of the can. |
Check with a nearby museum or art gallery. Art restorers use some type of adhesive to reattach flaking paint on paintings. It would need to be really good at that as well as being non damaging to the painting and removable in the future. They should be able to steer you in the right direction. Les
| Maytag Wooden Wash Machine with Upright engine Project | Dennis Wyatt | Antique Washing Machines | 3 | 11-29-2011 02:59 AM |
| Corn Sheller | Butch50 | Farm + Industrial Antiques and Collectibles | 2 | 11-09-2011 11:02 PM |
| Pictures Needed: Wooden IHC Corn Shellers | Colin Rush | Farm + Industrial Antiques and Collectibles | 6 | 04-07-2009 11:27 PM |
| Wooden Handle for Corn Sheller. | DougM | Farm + Industrial Antiques and Collectibles | 5 | 09-09-2007 10:34 PM |
| IHC wooden corn shredder--help needed | John Hall | Farm + Industrial Antiques and Collectibles | 6 | 11-19-2006 07:26 AM |
