1893 Dayton Serial #3 Outside for 101 Years
this thread has 123 replies and has been viewed 26725 times
Old 02-27-2012, 11:38:02 AM
BuckeyeMan BuckeyeMan is offline
Default Re: 1893 Dayton Serial #3 Outside for 101 Years
This is some of Greg Johnson's handy pattern work. 1st photo, 2nd. one is of the original bracket that held the water pump on the skids.
I made up a drawing when Greg was here in Oct. (to scale) and gave it to him and he made the pattern and sent it off to the foundry. Finished bracket is the last photo............DH
Old 02-27-2012, 11:46:25 AM
Dam, forgot the photos. ........DH
Old 02-28-2012, 02:17:46 AM
Here are more photos of some of the work that needed to be done on the engine. 1st and 2nd photo is the hubcap that goes on the end of the crank (so you don't get your sleeve hooked on the end of the wheel Key) To remove all the pitting from it there was about .060 taken off it. After the machining, it was sanded to remove the tool marks, not pictured.
3rd photo is of the idler gear for the cam timing, a small cut was taken from the sides to remove the rust from it.
I was ask how to make the crowned nut and bolts today by PM. and this is how I do it. You need to grind a tool with the radius you want to put on your bolt head, and turn is slow not to get any chatter in your tool..............DH
Old 02-29-2012, 02:56:22 AM
The Connecting Rod was one part I was up in the air about, Paint it, and what color, (engine color or black) leave it as is, or clean it up. It was pitted real bad. I ask for a few opinions from a couple of well respected engine guy's on what they would do. In the end I decided to re-machine it, and after about 4 hours I thought I should have gone a different direction.
I had it set up in the Mill to re-cut the sides, that took about 6hours, them when I got it in the lathe I found out there was about .075 taper in it.(from crank to piston end). So I went to work with 80 grit sand paper. That made a big mess, so the next thing was the file, what is call a long angle mill file. I spent about 8hours one day and about 4 more the next day. I was able to get about 90% of the pits out with the file, some where real deep. I was able to turn the crank end. I guess it was all worth the work. I think it come out alright, and if the rest of you ever do a restoration on something that was this bad, you will soon learn how to use a GOOD File.............DH
Old 02-29-2012, 07:39:45 AM
LCJudge LCJudge is offline
Yeah, but Dave you have to admit, it is a lot of fun!
Tommy Turner
http://picasaweb.google.com/Lcjudge
Old 02-29-2012, 11:06:57 AM
Yes it is Tommy..........
Old 02-29-2012, 03:54:59 PM
Kevin Kusel Kevin Kusel is offline
Dave thanks for sharing the updates and the photos.
KK
The Following 3 Users Say Thank You to Kevin Kusel For This Post:
  #48
Old 02-29-2012, 04:26:18 PM
Wayne Grenning's Avatar
Wayne Grenning Wayne Grenning is offline
Images: 72
Dave, Great story, Great engine, thanks for sharing. I am sure once you get the whole project together you will not regret spending the time cleaning the connecting rod. I can't imagine seeing the finished engine all together with a silver painted rod.... Wayne
The Following User Says Thank You to Wayne Grenning For This Post:
  #49
Old 03-01-2012, 10:59:39 AM
Here is some of the fine work that Gary Stoner has done for us. The brass pieces had all been worked over with a pipe wrench.
He also made new valves, and stems. The old ones had seen better days. Again my thanks goes out to him, I know he's got lots of time tied up in this and away from his Watkins project.........DH
Old 03-01-2012, 11:18:12 AM
Here are a few more photos of some of the work I'v been doing. As you can see everything needed to be remade and this is just part of them.
Gary did make the rollers in photo #3 and then hardened them for me. And the last photo is of the newly machined head and the finished Crank Hub Cap. I also have got the Piston and rod back together and in the cylinder and the cylinder is on the crank case, and I'v got the main caps shimmed up and adjusted. So its starting to all come back together..............DH
Old 03-01-2012, 11:33:11 AM
And a few more photos, The front of the cylinder where the valve chest goes on, and the inside of the Valve chest. These part's most have been a real pain in the butt for the Pattern maker. And no that's not rust in the two center holes in photo #2, its never seize. It might need to come back apart again in 120 years................DH
Old 03-01-2012, 05:03:46 PM
Ray Cardoza's Avatar
How long are those valve stems.
Old 03-02-2012, 02:58:04 AM
Here you go Ray. and the head of the valve are 2 3/4". I think maybe Dayton might have used the longest valve stems of any engine Builder............DH
Old 03-02-2012, 05:33:34 PM
over two feet
Old 03-03-2012, 12:48:36 PM
Dustin D Ehli Dustin D Ehli is online now
Images: 15
Id say your only competitor for those valves would be the exhaust valve from a stickney
Having a blast preserving the past.
My Youtube Channel
The Following 3 Users Say Thank You to Dustin D Ehli For This Post:
  #56
Old 03-06-2012, 12:55:28 PM
Here is a few photos of some of the work that I have gotten done on putting it back together.
Piston is in, Main and Rod bearings are all adjusted to where they need to be, Valve are lapped in now with the valve chest bolted in place. I know I'm running behind, But there is other things to do. I'll try harder.......................DH
Old 03-06-2012, 01:07:34 PM
Don Selmer Don Selmer is offline
Images: 15
Come on Dave, you got plenty of time. You still have just a little less than 3 months to Coolsprings. ( Counting that you'll going to be there a week early anyway.)
---------- Post added at 01:07 PM ---------- Previous post was at 01:02 PM ----------
Dave, Just curious, I see the connecting rod has an area relieved on one side ( ? ) Is that for clearance or is the other side relieved as well. If I owned a DAYTON I probably would know the answer, but I don't.
Old 03-06-2012, 06:02:21 PM
Don I have also been working on my 8Hp Foos SE. So I can get it there also............
And yes the other side is also relieved, don't know any reason, there is nothing in the way or even close to it..............DH
The Following 2 Users Say Thank You to BuckeyeMan For This Post:
  #59
Old 03-06-2012, 10:20:39 PM
KyleBlankenship KyleBlankenship is offline
dave, its looking good!!!!!
The Following User Says Thank You to KyleBlankenship For This Post:
  #60
Old 03-13-2012, 11:14:20 PM
Work is still going on the Dayton, just a little slow. Got these castings back a few weeks ago and got around to machining them over the weekend. Photo 2 shows one of they original bearings that the water pump shaft ran through, they other was more like what the new casting look like. When they are all finished they will have babbitt poured in them. I also got the Water Pump put together and got it mounted today..............DH
The Following 5 Users Say Thank You to BuckeyeMan For This Post:
Van Duzen 1893 3 1/2 HP Restoration Project -- page 8 Wayne Grenning Antique Gas Engine Discussion 36 06-22-2013 07:48:01 AM
Van Duzen 1893 3 1/2 HP Restoration Project -- page 11 Wayne Grenning Antique Gas Engine Discussion 24 12-15-2011 02:11:18 PM
Van Duzen 1893 3 1/2 HP Restoration Project Wayne Grenning Antique Gas Engine Discussion 0 07-05-2011 08:25:50 PM
Deutz Otto 1HP (French version) 1893 Lumenium Antique Engine Photos 6 04-06-2007 02:40:17 PM
