Onan Points plunger seal
this thread has 9 replies and has been viewed 1673 times
Old 02-11-2012, 06:44:11 PM
pnora pnora is offline
Default Onan Points plunger seal
My project needs the points plunger boot/seal. My parts book does not show it. My unit is a 5cck-3r/13j . Thanks.....
Old 02-11-2012, 07:04:45 PM
Billy J Shafer's Avatar
Default Re: Points plunger seal
Onan removed the seal. After it was found out. That it would turn in to a pump and pump oil into the point box. I have removed many of them.
Old 02-11-2012, 07:07:01 PM
Thanks billy. Makes sense. One less part to find.
Old 02-11-2012, 11:30:31 PM
Leon N. Leon N. is offline
Billy, I presume your comment applies only to the CCK design. I would not remove either plunger seal from the JB design. The contacts are too close and you can imagine what oil vapors would do to electrical contacts.
Leon
Old 02-11-2012, 11:35:30 PM
The only problem that I know of. Was with the CCK type plunger seal. Never heard on any problems with the j unit.
Old 02-12-2012, 11:22:04 AM
Billy, WRT the JB, that is good news, I guess.
Leon
Old 02-12-2012, 03:29:38 PM
George Clark George Clark is offline
Default Re: Onan Points plunger seal
there was a revision to the onan way back in 74 that eliminated the plunger seal on verticle mounted points like the ones you have because it acted like a pump and brought oil into the point box,so they are not needed,further info contact me at georgenfw@hotmail.com
Old 02-12-2012, 04:12:38 PM
Doug Sather Doug Sather is offline
pnora; CHECK YOUR CRANKCASE BREATHER
The Following User Says Thank You to Doug Sather For This Post:
Old 02-12-2012, 05:28:39 PM
Stephen Girouard Stephen Girouard is offline
maybe not yours but alot of old units i see have alot of blowby, which naturally blows oil out, what i like about onan filler tubes is they except the breather caps that twist on valve covers of old chevys, just a tip for units that are blowing by & still running well, as most onans can pull a full load worn out sometime you dont wanna take them apart, crankcase pressure is not good
Old 02-12-2012, 08:03:01 PM
I am aware of blow by. I am in the midst of getting the bugs worked out and saw my plunger boot all dry rotted. Thanks for the help.
Onan Point Plunger pnora Onan Generators 11 02-11-2012 09:54:49 PM
Onan RDJC Front Oil Seal Leaking 60 CrewCheif Onan Generators 8 03-22-2011 03:44:50 PM
Kohler 10hp K241 spec 46520D points plunger problem bass3139 Garden Tractors / Mowers / Scooters 5 03-17-2010 07:59:46 PM
Crank oil seal for Onan 4 kw Renee Onan Generators 12 12-25-2008 12:07:37 PM
PE-75-AB generator points and oil seal Mike Fitz Military MEP and Aircraft Gen-Sets 6 07-02-2008 08:58:25 AM
