Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel Engines
Vintage Diesel Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Fairbanks Morse 40 HP Y-VA
We had to tear the building down to remove the engine. This thread is continued from thread...
this thread has 27 replies and has been viewed 4373 times
Old 03-13-2012, 10:06 AM
heins heins is offline
Default Fairbanks Morse 40 HP Y-VA
This thread is continued from thread "Fairbanks Morse engine".
heins
This engine powered an irrigation well in Nebraska with a flat belt. We are getting it ready to move. The piston is standing by the barrel in the picture.
I still haven't found the ser # of the engine stamped on it.
Old 03-13-2012, 11:01 AM
Tom Weatherford Tom Weatherford is offline
Default Re: Fairbanks Morse 40 HP Y-VA
The serial # should be on top of base on a flat.
Tom
Old 03-13-2012, 08:04 PM
Tom, the engine is sitting with the crankshaft east and west, the flywheel is to the west. On the southeast corner someone has bolted a flat piece of metal for a step. You can see it in one of the pictures I posted earlier. Could the ser# be under that step?
Old 03-14-2012, 10:01 AM
This is the original belt pulley that was mounted on the flywheel shaft that powered the well. It is made out of wood except for the bolts and four castings the bolts go through to clamp onto the shaft. It is 42" in dia and 11" wide.
Old 03-14-2012, 10:20 AM
Question Re: Fairbanks Morse 40 HP Y-VA
Did you get the pump too?
Old 03-14-2012, 01:36 PM
I didn't get the pump but I did get the pulley the engine drove. It is in the picture if you look close you can see it in front of the electric motor that is on the well now. The engine pulley is vertical and the pump pulley is horizonal.
The Following User Says Thank You to heins:
Old 03-16-2012, 09:14 AM
I found a number on the flywheel 610031. Could that be the ser#? If it is the engine ser#, what would the year be?
Old 03-16-2012, 12:46 PM
Scott Hosack Scott Hosack is offline
That would be the serial number on the flywheel and also would be a 1925 with that number. I am guessing this would be a 32A with that early of a serial number.
The Following User Says Thank You to Scott Hosack:
Old 03-16-2012, 05:58 PM
Chuck Moss's Avatar
Chuck Moss Chuck Moss is offline
Aloha,
I believe that the 32A designation is a renamed Type Y Style VA, and that the Y VA was not on the market long before the renaming.
Chuck
The Following User Says Thank You to Chuck Moss:
Old 03-16-2012, 08:36 PM
Chuck, I have been wondering where you have been hidding! This is the engine I have been trying to see and the boyfriend wouldn't let me. The gal sent him packing and I got my foot in the door!
Old 03-16-2012, 09:00 PM
Chuck Moss's Avatar
Aloha Frank,
I'm out here, new thread as soon as I reduce some picture to fit. If you don't have a manual, I think this one is about right:
http://www.oldtacomamarine.com/fairb...uctions_lg.pdf
Chuck
Old 03-18-2012, 06:23 AM
Yamawhoo Yamawhoo is offline
Hello Frank,
Ive been trying to get ahold of you.Please email me when you get a chance.Thanx.
Herm
Old 03-20-2012, 08:51 AM
jsjollyCO jsjollyCO is offline
Happy Birthday to Frank - born 1st day of spring! I look forward to helping him with this engine all that I can as very excited to see piece of history run in present.
The Following User Says Thank You to jsjollyCO:
Old 03-20-2012, 10:38 PM
DirtbikePilot DirtbikePilot is offline
That is such a nice engine with that HEAVY flywheel! I'd love to see a video of it running nice and SLOW when you finish it.
You're in Colorado? I just might even take a drive your way to see it run in person some time.
Old 03-24-2012, 08:44 AM
Dirtbikepilot, it will be a while if I get the engine running but if you are out this way, stop in and look at the engine.
Scott H, I found the ser# on the engine. It is on the flat on the rear right corner where you said it is. It is easy to find something if you know where to look. The ser# on the engine is the same as the flywheel.
I was able to move the flywheel about 4" with my 55 ton porta power. It didn't even "grunt" so I will be able to take the flywheel off when we load the engine.
Old 03-24-2012, 12:39 PM
J.R.Smith J.R.Smith is offline
The Serial Number will also be on the Key in the Flywheel and Crankshaft. J.R.
The Following User Says Thank You to J.R.Smith:
Old 05-15-2012, 10:40 AM
We went to Nebraska and got the engine. It is missing some parts, if any of you know where I can find part for this engine, let me know.
Ive {I V}
Nebraska is where Ive spent her working life
In an iron clad building she pumped water with no strife.
When she would start up, neighbors would rally
For when she was running, you could hear her up and down the valley.
She is a proud engine and not a weasel.
She was pumping water for thirsty crops before "Cat" had a diesel.
To see her scrapped and sent to China, a fate that would be so final.
For she is made of iron and steel, and not of flimsy vinyl.
We couldn't let her return as a roller skate
And you won't see her on the shelves of Harbor Freight.
She was silenced when they put an electric motor on the well.
She did her work and we won't dwell.
She has done her work and now retired,
And now it is time for her to be admired.
Old 05-15-2012, 10:48 AM
John Merry John Merry is offline
Banned
heins--I enjoyed your poem. That homebuilt lift is neat too. Thanks for saving that cast iron monument.
The Following User Says Thank You to John Merry:
Old 05-20-2012, 10:36 PM
kcdepot kcdepot is offline
Heins - great poem. KC Depot
Old 05-27-2012, 09:07 AM
JR Smith the flywheel key has the ser# on it. It has the engine ser# on the engine base, flywheel, and flywheel key. They are all the same #.
We took the flywheel to the museum so people could see it. It will be a while before I am ready for it.
15 HP Fairbanks Morse YH heins Vintage Diesel Engines 6 03-23-2011 01:50 PM
FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit? LShap1777 Antique Gas Engine Discussion 4 09-12-2008 11:03 AM
25 HP Fairbanks Morse N Willyb Antique Gas Engine Discussion 7 08-22-2008 09:22 PM
Fairbanks Morse Z-52 Doug Kimball Antique Gas Engine Discussion 2 08-02-2008 11:08 PM
How many Fairbanks Morse 20's Alan James Antique Engine Archives 1 01-25-2003 06:32 PM
