Steam Engines
Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Stationary Steam & Traction Engines
Stationary Steam & Traction Engines Antique steam engines, traction engines, their boilers and the related things that make them run.
Craigslist steam engine... In BOISE, too far for me
http://boise.craigslist.org/atq/2901979205.html
this thread has 32 replies and has been viewed 3876 times
Old 03-19-2012, 08:34 AM
Firewoodguy Firewoodguy is offline
Default Craigslist steam engine... In BOISE, too far for me
The Following 5 Users Say Thank You to Firewoodguy:
Old 03-19-2012, 08:42 AM
HalfKeck's Avatar
HalfKeck HalfKeck is offline
Default Re: CL find....steam engine.. In BOISE,too far for me
That looks like it could be a nice engine for someone if the boiler is not shot. One of the Case experts will have to id it for sure, but it looks alot like the 45 in the city park here in town.
160hp Keck: the search continues.....
The Following User Says Thank You to HalfKeck:
Old 03-19-2012, 08:43 AM
i hope a staker gets this!
Old 03-19-2012, 01:08 PM
Bruce L Bruce L is offline
what size do you think it is?
Old 03-19-2012, 01:55 PM
Colin's Avatar
Colin Colin is offline
Images: 138
Lightbulb Re: CL find....steam engine.. In BOISE,too far for me
Appears to be a 1910 45Hp. we used a 1910 60 boiler like this on our 20 with long smoke box but lap still on the left. first year for long smoke box. but we were able to shorten our smokebox to go with the old parts. Most 1910 75s had the lap up on the right. but seemed to take one more year for the smaller engines.
pretty complete looking unit. even some drawbar and back end stuff to work with.
Steam licenced in Manitoba, Minnesota & ND * U of Rollag Class of '02
HD Farm Equipment Tec.
The Following 5 Users Say Thank You to Colin:
Old 03-19-2012, 02:02 PM
Colin,
Was 1910 the last year for the big loop front axle? That's a neat looking engine, looks like a good start for someone.
Mike
Old 03-19-2012, 02:22 PM
Beth V's Avatar
Beth V Beth V is offline
I looked up their site. It is internet bid only. The engine currently has 25 bids with the highest at $2925. There is what appears to be an original style 2 wheeled tender after it. Its 12 bids have it up to $65.
http://pickettauctions.auctionflex.c...enum=1&lang=En
At those prices, it could be worth obtaining as lawn art....
The real question is: Does anyone know the engine's history or close enough to inspect it before Wed?
Beth
Old 03-19-2012, 03:02 PM
threecase threecase is offline
Seems pretty cheap to me. I agree with Colin, a bobtail 45 horse with an original trailer. All for the steering gear is there, its probably worth more than the engine... I would think the steerable trailer would bring that by itself. Clearly the boiler is completely gone, you can see the flues are removed and the corrosion has eaten completely through the flue sheet in the smokebox. The bobtail is gone, something unoriginal in its place. The guards are gone, pretty much everything that could be unbolted is gone. At 3K there is some room to build a new boiler and perhaps still come out OK.
It really depends on what else is there and the condition. I wouldn't be surprised to see a bit more by the time its done, just because of the trailer.
Old 03-19-2012, 03:05 PM
30-90 Russell 30-90 Russell is offline
I have pic's of the engine in detail I will post them tonight when I get some time. This is the same place our 16 Russell engine came from a few years back.
I will buy it if its going of lawn art that is a dam nice engine
Zach
The Following 2 Users Say Thank You to 30-90 Russell:
Old 03-19-2012, 03:11 PM
Ok Colin 1910 45Hp sound about right, the first things i saw was the older axles and smokestack. It has a newer steering wheel, the old stye preheater, 36 flues, no water pump,the position of the steam dome is to the rear of the boiler a waters 2" governor and a Gould balance valve. Is this balance valve common?
Old 03-19-2012, 05:32 PM
Default Tender listing - In BOISE,too far for me
Looking again at the auction, it appears that there are two tenders? Or is the trailer is selling separately from the engine, and it selling for $75.00? I can't tell. One looks like it has cables and the other doesn't.
The steering gear is left on the front axle and on the side of the firebox on the engine. Hopefully whoever is buying the engine would part with the set up if there is only one tender.
---------- Post added at 02:10 PM ---------- Previous post was at 01:36 PM ----------
The engine came from Lodgepole Nebraska and has been in Idaho since 1969. The Nebraska owners were the original owners. The smoke box is not original to the engine, it has been replaced, but the welding is not completed. That is why there is the seam where daylight is coming through.
I spoke to the auctioneer, there is only one trailer, it does not come with the engine and he is removing the photos of it from the engine listing.
---------- Post added at 02:32 PM ---------- Previous post was at 02:10 PM ----------
For Chuck, The serial number on the boiler is 62x51 the x is not readable.
The Following User Says Thank You to threecase:
Old 03-19-2012, 06:55 PM
Colin's Avatar
Images: 138
I think the dish steering wheel came about 1907/8. and im not sure on the hoop on the front axel that Mike mentioned. i think its original for a 1910 45 or 60, but pretty sure a 1910 75wouldn't have it. you see the odd case engine with balanced valve, but not too many. 3Case i think it still has the older type more square bobtail tender on it. another thing im not exactly sure on the cutoff. most engine of this age have full bunkers or something home made on the back of them. i need to get my own parts book to go through, dads are getting worn out!
Here's a scan from the 1912 catalog. must have been a later 1911 engine with the new steel heater, but still has the square front axel.
The Following User Says Thank You to Colin:
Old 03-19-2012, 07:35 PM
Colin's Avatar
Images: 138
Question Re: Tender listing - In BOISE,too far for me
Im not seeing the tenders Can someone post a link
Old 03-19-2012, 09:23 PM
It looks like one could fly out to the auction and purchase everthing they need to buy an engine and even haul it back..............they even have pumps and hoses and just about everything else other than a change of clothes for the motel and a toothbrush...............
Old 03-19-2012, 09:48 PM
KG1584's Avatar
KG1584 KG1584 is offline
Images: 163
Well - internet chatter is making the auctioneer more money. This morning when I looked the tender pics were with the engine. Now the tender is off by itself. More than likely they came together but now they willl probably be seperated. What a shame
3case - 2:00 p.m, you mention the tender is worth as much as the engine. Post at 4:30 you talked to him and all of a sudden the tender is now being sold by itself. Autioneeers are not dumb - when someone says the tender is worth as much as the engine what would do??
Quiet talk is the best sometimes
Doug
"Pimp my Keck"
www.steamsmith.com
The Following User Says Thank You to KG1584:
Old 03-19-2012, 09:54 PM
Engine Pic's 1
Steam engine trip March 2007 087.jpg   Steam engine trip March 2007 094.jpg   Steam engine trip March 2007 102.jpg   Steam engine trip March 2007 104.jpg
The Following 8 Users Say Thank You to 30-90 Russell:
Old 03-19-2012, 09:56 PM
Engine Pic's 2
Steam engine trip March 2007 105.jpg   Steam engine trip March 2007 106.jpg   Steam engine trip March 2007 108.jpg   Steam engine trip March 2007 109.jpg
The Following 6 Users Say Thank You to 30-90 Russell:
Old 03-19-2012, 10:15 PM
Colin's Avatar
Images: 138
Default Re: Tender listing - In BOISE,too far for me
[/COLOR]For Chuck, The serial number on the boiler is 62x51 the x is not readable.
That wouldn't make sense for a boiler #... 6251 itself could be close but adding 11000 only pushs the serial # to the 17k range and i think its a bit later than 1906 but i can see now in Zacks pictures that smokebox is welded on. so there's no way to know if its a 1910 boiler, or just made to appear that way. Its got the older lock nuts on the axels, and old levers and valve gear which would be more 1909 or older.
Old 03-20-2012, 01:35 PM
Is it just me or is the firebox bagged a little bit down towards the bottom? Can't tell for sure, but that's what it LOOKS like in the pics..... The stays in the crown sure have lots of threads on 'em....could be a really nice boiler......COULD be......
Anyone else notice the sweet little 5 bottom gang plow for sale in the same auction? That'd be a neat piece to have, that's for sure!
Mike M
The Following 2 Users Say Thank You to Mike McKnight:
Old 03-20-2012, 03:31 PM
I don't like how now they are going to take of the steering brackets for the water tender. If it came on this unit it should be sold with this unit. Its funny too how now the description changed to a 1910 45 hp
The Following User Says Thank You to Bruce L:
New from Boise, Idaho hannibal61577 Smokstak Forums Meet and Greet 2 08-01-2011 08:21 PM
Try Craigslist? Tanner Remillard Antique Gas Engine Discussion 3 05-15-2008 10:16 AM
Hauling from Portland In to Boise Idaho hitmis1 Antique Gas Engine Discussion 2 04-25-2007 12:59 AM
du boise justin jenkins Antique Engine Archives 3 03-21-2003 09:21 PM
