Question: cutting keyways without a mill
this thread has 10 replies and has been viewed 5710 times
Old 03-20-2012, 06:57:28 PM
Jerry B Jerry B is offline
Default Question: cutting keyways without a mill
Hi'' guys I have a question I do not have a mill are there any way to make something so I can cut keyways in a shaft like a 5/8 or 3/4 shaft, I have metal lathes. Think for your time Jerry B.
Old 03-20-2012, 07:24:49 PM
MadMachinist MadMachinist is offline
Default Re: Question
Does the key way go to the end of the shaft?
If so:
Drill a hole at the end of the key way just a little deeper than the depth of the key way.
Clamp the shaft in your lathe chuck and find a way to lock rotation of the spindle. (C clamp on a jaw resting upon the ways, etc.)
Sharpen a tool bit like a parting tool but make the width what you need for the key way width.
Put the tool in your holder sideways so the cutting edge is towards the chuck and adjust the height so the center of the tool is on center of the shaft.
Now just use the carriage on the lathe to move the tool left and right as you feed the cross feed in a few thou at a time and broach the slot.
It helps if you have a stop on the carriage so you don't have to slow down as you get to the hole. A little cutting oil is good too.
I've done this to do inside keys in bores that I didn't have a broach for.
Good luck.
The Following 5 Users Say Thank You to MadMachinist For This Post:
Old 03-21-2012, 12:01:01 PM
Get a milling attachment that fits either on top or in place of the compound. Here is one on ebay.
http://ebay.com/itm/PALMGREN-USA-MODEL-250-MILLING-ATTACHMENT-LATHE-SOUTH-BEND-LOGAN-ATLAS-/170808073948
With this attachment you mount the cutter in the chuck or collet attachment. You can cut standard keys with an end mill or woodruff keys with the correct cutter. I have seen really good results on a 9" South Bend withone of these. I think the more common ones you find are made by Palmgren. There are many manufactures of these. These are used with the lantern style tool post to mount to the compound.
Here is a guy who modifyed his X Y tabe for his drill press.
http://www.chaski.org/homemachinist/...ing+attachment
Richard W.
The Following User Says Thank You to Richard W. For This Post:
Old 03-21-2012, 07:22:28 PM
Tencubed Tencubed is offline
The old way. Cape chisels and files.
Mike
The Following 2 Users Say Thank You to Tencubed For This Post:
Old 03-21-2012, 07:37:05 PM
oldtractors's Avatar
Images: 5
I don't have any broaches so I cut all of my internal keyways just like is described in post #2. I would think it would work on keyways on shafts as well. The actual shaving goes very fast. Once you have a tool ground to the right shape, you can cut a 1/4 x 1/8 slot in only a few minutes.
Jim Evans
Old 03-21-2012, 07:58:00 PM
OTTO-Sawyer's Avatar
Those suggestions all work for making a long keyway.
If you need a woodruff key (the 1/2 moon shaped ones) then you just about need a mill or a milling attachment for the lathe.
On softer material like brass or aluminum you might get by with a good drill press and one of those little cross-slide tables.
Even easier would be to ask around and find a friend or a small machine shop in your area with a mill and give them a few bucks to do it for you.
Old 03-21-2012, 09:11:31 PM
Keith B. Keith B. is offline
Default Re: Question: cutting keyways without a mill
How long are your keyways and how long are the shafts that they will be cut?
Old 03-21-2012, 10:15:32 PM
Before I had a mill I made an attachment for my lathe. A heavy piece of angle iron in place of the compound, squared up to the face of the chuck. Place a 3/8" end mill in the chuck, using the cross feed mill a slot across the angle iron. Put a countersink cutter in the chuck and make the slot a "V". Drill and tap holes above and below the V, drill flat stock to match the holes, these will be the hold down plates to hold the shaft in the V. Clamp the shaft in the V slot, use the proper end mill to cut your key way, it will center automatically.
The Following 4 Users Say Thank You to J.B. Castagnos For This Post:
Old 03-22-2012, 10:43:07 AM
Exactly right. Also with the milling attachment you make square or hex parts. You are only limited by your imagination what you can do.
Richard W.
Old 03-22-2012, 02:13:28 PM
Forrest A's Avatar
Mount a block on your cross slide that gegisters on one of the slots. A lip machined on the bottom would be the way to do it. The block must be several inches taller than the centerline of the spindle and should be several inches long and thick. Place a long 1/8" milling bit in a collet in the spindle and mill a slot accross the face of the block using the cross slide feed. Next install a 45 degree chamfering catter and make several passes deep enough to be able to lay the shaft into the cut so it registers in the opening. You mat need to redo the 1/8" depth a couple of times and make sure some of the 1/8" slot remains when the 45s are done, about 1/8" deep would be good. Clamp the shaft into the newly cut register that will have the key way cut into and then insert the milling bit to match the keyway needed and cut the keyway to the depth needed. Whats cool, if done right you can take it off and reinstall it and it will always be lined up with the spindle. It also can be used to drill perfectly centered holes in round stock too with a drill chuck or collet/drill in the spindle.
Old 03-23-2012, 08:38:20 PM
Robdiesel.707 Robdiesel.707 is offline
Hacksaw, hammer, cape chisels and a file, thats the way we were taught in the Army!
Grist Mill Question daydk1 Farm + Industrial Antiques and Collectibles 2 12-24-2013 06:10:54 PM
Cutting Keyways Francis Machine Shop and Tool Talk 2 10-29-2011 07:53:17 PM
Burr mill question TheToolman Farm + Industrial Antiques and Collectibles 7 11-28-2009 11:10:00 AM
Appleton No.22 Burr Mill Question Bryan Brooks Farm + Industrial Antiques and Collectibles 1 06-01-2005 10:34:14 AM
question about old grist mill motor Barb Durci Antique Engine Archives 5 07-16-2004 08:46:57 AM
