Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel Engines
Vintage Diesel Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Bamfords Z4 Connecting rod bearing needed
I am restoring a Bamfords Z4. This is a single cylinder 8 hp diesel. The bearing shells have a...
this thread has 22 replies and has been viewed 2469 times
Old 03-24-2012, 05:54 PM
rleonard rleonard is offline
Default Bamfords Z4 Connecting rod bearing needed
I am restoring a Bamfords Z4. This is a single cylinder 8 hp diesel. The bearing shells have a trademark circle with a VP inside. Numbers are M2116 for the upper with an oil groove and M2115 lower, plain. They are steel backed. Journal diameter is 3.250. Width is 2.40 and bearing OD is 3.414
Does anyone recognize this trademark? Have a spare set setting on a shelf?
Bob
Old 03-26-2012, 09:30 AM
Default Re: Bamfords Z4 Connecting rod bearing needed
As found in the barn
Pardon my messy workbench. _Lots going on in the shop these days.
Bob
Old 03-30-2012, 09:02 PM
Also looking for a crank handle. 2 1/2 shaft
Bob
Old 04-03-2012, 10:49 PM
I needed a new connecting rod bearing. Cannot find one through my usual sources and getting impatient on non returned email inquiries.
Order a alloy 932 bronze tube from McMaster.
Carefully saw it in precisely half on the milling machine with a slitting saw.
Super glue it together.
Turn the OD
Bore the ID to fit and test
Finish up with oil grooves, oil wedges, holes, and the lock tabs.
It took most of the day today. Fits perfect!
Bob
I should add;
After turning the OD of the bearing, the halves were assembled in the rod. There is .003 compression on the cap. The rod cap bolts are torqued and then the ID is bored to size on the mill. Then it was a matter of completing the oil grooves and holes.
Bob
The Following User Says Thank You to rleonard:
Old 04-06-2012, 10:17 PM
I have a crank handle that fits now. The head has been all gone through and is on. Valves are set, and now fitting new Gib Keys.
Next will be working on the injection system.
Bob
Old 04-12-2012, 11:15 PM
Ready for primer, but too cold and windy outside.
I made up this replacement lower water flange. The original is made to slip a hose over. This one will go out to a T where I can attach a drain valve.
Little by little....
Bob
Old 04-13-2012, 07:23 PM
Contaucreek's Avatar
Contaucreek Contaucreek is offline
Looking good Bob, Nick camera shy ?? Was the ring gear just sweated on the flywheel ?? I have often thought about cutting a flange from plate and then just welding the appropriate fitting on. Nice to have machine tools though.
A life lived without challenge is a life wasted
Chris Hadfield, Canadian Astronaut
Old 04-13-2012, 08:40 PM
Hi Paul,
Nick was outside guarding the shop!
The Ring gear came off without too much effort. It was a shrink fit. The teeth were in such bad shape, had to be either replaced or eliminated. The rest of the starting arrangement was quite crude so off it will stay.
I have a crank now and it should start pretty easy, just like a Lister. The ring gear being gone makes it safer. I do not need an exposed "saw blade"
If I can find a gear at a reasonable price I'll put it back on though. Mostly just because it was there.
Bob
Old 04-16-2012, 09:18 PM
It warmed up, humidity dropped, and the wind died down. Time for primer!
Bob
Old 04-16-2012, 09:33 PM
dieseladdicted dieseladdicted is offline
As usual, top notch work Bob Thanks for posting it.
Old 04-17-2012, 06:42 AM
GeneratorGus's Avatar
GeneratorGus GeneratorGus is offline
Glad I stop to take a look, I thought this was just a parts search.
Nice work.
Old 05-04-2012, 10:45 PM
I was able to make it green today!
I'm looking forward to final assembly.
Bob
Old 05-15-2012, 08:12 PM
Been in somewhat of a lull here. My fuel injector is still out and I placed another call today on it.
I've beei training myself in Solidworks and have used this tool to design the carriage (or trolley for our friends in the UK).
Still a work in progress.
Bob
Old 05-16-2012, 06:48 AM
Bob, dont forget spokes
Old 05-20-2012, 08:05 PM
I am still having trouble getting spokes into the model. Polar arrays at angles. There will be spokes though. All the parts are machined and the first one is being welded.
Bob
Old 05-25-2012, 07:29 PM
Wheels on
Old 05-25-2012, 07:48 PM
K-Tron K-Tron is offline
You may want to hit that new lower water flange you made with a needle scaler to make it look like cast iron. Otherwise, awesome work, I cant wait to see and hear it run.
Keep up the good work,
Chris
Old 05-28-2012, 10:54 PM
I did a test assembly today. Now all apart for powder coating. I'll stain and urethane the wood next week. Sorting out the cooling system also.
Injector tips arrived from Peter. Thank you. Maybe I can make some noise with it this week!
Bob
Old 05-30-2012, 11:19 PM
Had a rough go at it today. _The engine is a little tight from the fresh rings, honed cylinder, seals and bearings. _I can get it spinning but once I flip the compression release it will not go over compression. _Two of us gave it our best but it wore us out. _Also the engine is close to the floor on a couple of 6X6's _Crank center is low so you really have to bend over, decreasing our cranking torque. _Lastly, I fitted a Lister crank since this engine was missing the original one. _The compression stroke is on the upswing of the crank. _You cannot throw your weight into rolling it over at the toughest part.
So I have rigged a coupling to spin it with a tractor PTO. _Not done yet but all I need to do is finish up the "dog" that engages the keyway.
Carriage metal parts are at the powder coater. Back next week.
Bob
Old 05-31-2012, 02:20 PM
Here is the rig to save my back. I spun it and a couple of revolutions later the Bamford sprung to life. It has been at least a dozen years since it ran last.
And finally...
http://www.youtube.com/watch?v=IT8OlInsO8Y
Run times were short since there is no cooling. It has freed up and I can now start it by hand.
Got stain on the oak frame
Bob
The Following 5 Users Say Thank You to rleonard:
John Deere E connecting rod bearing Scott Antique Gas Engine Discussion 2 12-01-2011 12:26 PM
Engine bearing needed pegasuspinto Small Air Cooled Gasoline Engines 3 06-20-2011 10:38 AM
IHC M 1 1/2HP Connecting Rod Casting # Needed WildIrishman52 Antique Gas Engine Discussion 2 06-19-2010 06:31 PM
Delco 850 Connecting Rod Bearing Jacob Warner Generators & Motors General Discussion 0 10-26-2009 03:10 PM
Bearing clearance on a 3hp Z connecting rod Ray Cardoza Antique Gas Engine Discussion 6 02-27-2009 05:16 PM
