Onan 3.0 AJ generator
this thread has 6 replies and has been viewed 2208 times
Old 04-02-2012, 04:31:01 PM
fgonzales fgonzales is offline
Default Onan 3.0 AJ generator
Can you kind people help me with installation. I could really use a manual users and parts. if anyone has information on how to install that would also help. Thanks
Frank
If you need to email my address is: ssgfrankgonzales@yahoo.com
Old 04-02-2012, 06:21:32 PM
John Ward John Ward is offline
Default Re: Onan 3.0 AJ generator
Frank
Please post the FULL model and serial number so someone can get you the proper manuals for your genset.
6.5 NH-3CR/16004P (1985)
The Following User Says Thank You to John Ward For This Post:
Old 04-02-2012, 06:30:20 PM
Thanks John my Onan is 3.0AJ-1R / 1607S Model #667174
Old 04-02-2012, 07:06:44 PM
I uploaded a picture if it would help.
Old 04-02-2012, 07:17:24 PM
Should be 3 manuals in your in-box.
The Following 3 Users Say Thank You to Max Thompson For This Post:
Old 04-02-2012, 08:06:47 PM
Max Thank You, Thank You. I received the service and the parts manuals. Not sure what happened to the 3rd manual. If not to much trouble could you please resend the 3rd manual. The two issues I'm attempting to resolve right now is (1) from my 12v source where do I connect the negative to the generator. (2) I want to use the generator in remote, I need the part number to order the cable and connector to accomplish this.
Old 04-03-2012, 07:52:03 AM
The operators manual should be in your box.
The ground cable is attached to a stud through the end of the generator section at about 11:00 on the one I checked. Anyplace on the generator or engine frame should work fine as long as you have a "good electrical bond", I would recommend a coarse star washer between the cable & the frame. "IF" there is a bonding strap from the mounting plate the generator sets on to the generator, you could ground to that plate. If you are going to mount it in a vehicle, I would bond the unit to the vehicle frame also.
Onan Gen set generator Bailes Onan Generators 1 11-07-2010 11:47:05 PM
Onan Generator Gaspipenicklioni Onan Generators 2 11-07-2010 03:43:38 PM
Onan DC generator help BGunn Onan Generators 4 08-14-2008 07:35:13 PM
Onan generator CEB5 Onan Generators 16 11-24-2005 09:15:20 PM
Onan Generator Chuck Rich Onan Generators 1 11-01-2003 07:05:05 PM
