Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
Scale Model John Deere E Gas Engine
this thread has 10 replies and has been viewed 3740 times
Old 04-07-2012, 03:34:12 PM
Roger U Roger U is offline
Default Scale Model John Deere E Gas Engine
Now that the Hired Man is almost finished i am now thinking ahead to the next engine i will be starting shortly which is a 1/2 scale John Deere Model E, This is a very comprehensive kit from Leroy Hoover, which includes many many castings in cast iron, and a nice trolley set up. The casting look of very high quality with no surface defects and the drawings are clear and precise.
Are there any problems i should be looking our for during machining.????
Regards Roger
Old 04-08-2012, 12:38:31 AM
BrianThomas BrianThomas is offline
Default Re: Scale Model John Deere E Gas Engine
I would like to see this build with pictures! Half scale? At this scale are the flywheels about 10"in diam ?
Old 04-08-2012, 10:00:16 AM
Gil Garceau Gil Garceau is offline
Here's one sold last fall in an auction In Michigan.
(not mine)
Gil
John Deere thumbnail:
The Following 2 Users Say Thank You to Gil Garceau For This Post:
Old 04-08-2012, 01:52:44 PM
Hi Brian
Yes the flywheels are cast at 10 1/4" diameter
regards Roger
Old 04-08-2012, 03:01:48 PM
Edwin
Hello nice looking engine,does the mag function or is it for looks?
Old 04-08-2012, 04:58:01 PM
I think the mag is for looks.
Old 04-08-2012, 07:59:51 PM
here is a few more example's of home made scale John Deere type E engines.John
http://www.youtube.com/watch?v=6FzBT...FofrxpkMHBpcI=
http://www.youtube.com/watch?v=93LQs...C7vs5V_feywHI=
Old 05-07-2012, 07:01:19 PM
Alexbpeterson Alexbpeterson is offline
Roger there is a video on youtube that has a model of a E thats is ran on a boiler/compressed air I have the blue prints in my email from it.
Old 08-24-2012, 12:06:43 PM
niceonetidy niceonetidy is offline
I bought a kit from Leroy, but did not get any setup instructions on how to time and run the engine, how much oil to put in etc,
Does anyone have a copy they could scan and send me please?
Old 08-25-2012, 03:23:31 PM
Just got my John Deere running, fill the oil until the oil runs out of the filler hole and the level will be about right, when running i found the oil splashed over the piston and the engine omitted a lot of smoke, after advice and help from others that use Smokstak i made and fitted an internal splash guard which cured the problem. Set the trigger to fire the engine about 10 Deg BTDC. The engine seems to flood if you are not careful, turn the needle valve only about half a turn, block the choke hole with you finger and turn the engine over by hand to draw fuel to the carb, half close the choke and the engine will fire on the flick of the flywheels if not then make small adjustments to the carb settings Regards Roger
Old 08-25-2012, 04:31:33 PM
Thanks Roger,
Good to hear your experience. Is there anything special to do in the gear case? Where the governors and levers work? Do the timing dots go on the inside of the crank case?
Scale John Deere plowing Emma Scale Model Engineering 3 08-28-2008 06:30:31 AM
John Deere Model E Sparkplug engine Christopher Markley Antique Gas Engine Discussion 3 07-18-2007 09:57:28 AM
1/5th scale model john deere tractors Jordan Scale Model Engineering 8 03-13-2007 10:46:46 AM
John Deere Model E engine production Stevie Antique Engine Archives 2 12-29-2002 08:17:20 AM
1/2 scale John Deere RWG Antique Engine Archives 0 01-09-2000 07:07:28 PM
