Wisconsin Engines
Wisconsin VH4D
this thread has 2 replies and has been viewed 2436 times
Old 04-16-2012, 08:52:33 PM
ChrisMD ChrisMD is offline
Default Wisconsin VH4D
I have a Bobcat 610 with a Wisconsin VH4D engine and it starts and runs for 3-4 minutes then dies Any ideas?
Old 04-17-2012, 09:40:57 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Default Re: Wisconsin VH4D.
Possible fuel restriction, sounds like it runs on the fuel in the carb until it runs empty then stalls. Is the fuel supplied by a fuel pump or gravity feed, need more info on what you do to restart. F.J.W.
Old 04-19-2012, 08:12:56 AM
Exclamation Re: Wisconsin VH4D
Check your filters. There probably is one in the tank, and debris may be blocking it. Chack also your fuel lines to see if they are deteriorating. Bits of rubber may be blocking the inlet to the carb. Personally, the filters are suspect. Check engine oil too - see if there is gas in it. If so, bad fuel pump.
Wisconsin VH4d vs. VG4D thahn1608 Wisconsin Engines 4 03-23-2012 01:50:33 PM
Wisconsin VH4D starter Help! dlancin Wisconsin Engines 4 09-07-2010 09:22:15 PM
Wisconsin VH4D Help! Muhji Antique Gas Engine Discussion 15 03-14-2010 12:17:46 PM
VH4D Wisconsin Richard F Wisconsin Engines 3 05-12-2008 12:51:19 PM
Wisconsin VH4D Chandler Wisconsin Engines 2 12-29-2007 05:21:56 PM
