Converting a Single phase motor into a generator
this thread has 8 replies and has been viewed 18476 times
Old 05-05-2012, 08:22:56 AM
robert hamilton robert hamilton is offline
Question Converting a Single phase motor into a generator
Hi im not sure if this it the right place but i have a 3hp metropolitan vickers electric motor that i want to convert into a generator to drive with one of my engines how would i do this any help would be great thanks
Robert Hamilton
Old 05-05-2012, 01:21:27 PM
Default Re: Converting a Single phase motor into a generator
If it is a brushless motor, your options are limited. Most motors will retain enough magnetism to excite as an induction generator when you spin them with an engine. Voltage output is somewhat dependent on how fast you spin it and what the voltage rating of the machine is when used as a motor.
HOWEVER, it will likely fall on its face when you put much of a load on it. Induction motors work best as generators when operated in parallel with the power grid or a larger generator. The grid excites the generator(supplys reactive current) and as long as the shaft is turning faster than synchronous speed, it will generate real power (WATTS) into the grid.
Now if you want to go with permanent magnets on the rotor, you can run at most any rpm and rectify the "wild AC" to DC and charge batteries, operate DC equipment and or run an inverter to go back to standard frequency AC.
The Following 2 Users Say Thank You to Jim Rankin For This Post:
Old 05-05-2012, 03:00:03 PM
Yes electric motors can be turned into generators Check out www.fieldlines.com . Of course it depends on what kind of power you want too, AC or DC? If you want plain old 120/240 60hz your better off with a normal generator, most here will probably suggest something green
I've been spending a fair amount of time reading the fieldlines site, lot of stuff there you won't learn out of a book.
The Following 3 Users Say Thank You to dalmatiangirl61 For This Post:
Old 05-05-2012, 05:10:56 PM
Joseph Joseph is offline
There is a book called Motors as Generators for micro-hydro power that covers this and tells how to fiqure the amount of capacitor excitation is needed. The ISBN number is 1-85339-286-3 and the author is Nigle Smith.
The Following 2 Users Say Thank You to Joseph For This Post:
Old 05-05-2012, 07:37:05 PM
Here is a link to a guy who did what you are talking about
http://www.qsl.net/ns8o/Induction_Generator.html
The Following 4 Users Say Thank You to Joseph For This Post:
Old 05-21-2012, 03:03:49 AM
The motor is a Repulsion induction motor would that make it harder to convert to a generator the motor has a set of brushers
Cheers Rob
Old 05-21-2012, 10:29:15 AM
Just as a guess, I expect you would see little effect from the brushes when they're riding the rotor. Normal speed for the motor will have them raised by a centrifugal mechanism. If there's a problem when they're down, lock them up.
Treat it like an induction motor as far as capacitors etc.
The Following User Says Thank You to Jim Rankin For This Post:
Old 05-21-2012, 05:04:21 PM
Merv C Merv C is offline
Rob,
While I don't know how it is done, a three phase motor with six terminals can easily be converted to a generator which believe has a 240 volt AC output.
I plan to do the same with a 3hp three phase motor I have here and couple it to my Blackstone Diesel.
Here is a link to a thread on the Stationary Engine forum.
http://www.stationary-engine.net/for...or+phase+motor
Merv.
The Following User Says Thank You to Merv C For This Post:
Old 05-25-2012, 10:51:28 PM
Here's a link to a very scholarly treatise on induction machines as generators.
http://www.frenchriverland.com/Motor...th_UK_1994.pdf
Another stupid question about converting from single phase 120v to single phase 240v! Patrick Onan Generators 7 11-30-2011 02:08:16 PM
3 phase motor using single phase paulmars Generators & Motors General Discussion 10 08-27-2011 10:51:17 PM
US Motor Div Generator Conversion To Single Phase 220V From Three Phase jimybud Generators & Motors General Discussion 4 06-27-2010 08:19:50 PM
Single phase motor/induction generator asandberg6 Generators & Motors General Discussion 7 01-19-2010 11:43:37 PM
Converting a Kohler Generator from 3 phase to single phase KendalPernod Kohler Generators 3 09-13-2005 10:08:28 PM
