Go Back   SmokStak > SmokStak® Support and Information > Smokstak Forums Meet and Greet
Smokstak Forums Meet and Greet Welcoming Smokstakers New and Old, a place to say a bit about yourself and post a photo if you're really brave. If you have a technical question, please post it on one of our other boards.
6-71 detroit diesel powered Ingersoll Rand air track drill
this thread has 4 replies and has been viewed 1902 times
Old 05-31-2012, 10:57:15 PM
notaalias notaalias is offline
Default 6-71 detroit diesel powered Ingersoll Rand air track drill
Greetings from Alaska. My name is Jim and I have been given the task of making operational an
Ingersoll-Rand Air Track Rotary drill, powered by a 6-71v Detroit Diesel.
The first order of business is getting it running properly. When I'm starting it up,
one of the exhaust manifolds loads up with fuel. Mind you that after I put out the fire and actually get it running, it settles down and starts running properly. It's the fire thing that I don't like.
Any thoughts?
Thanks Jim
---------- Post added at 06:57 PM ---------- Previous post was at 06:45 PM ----------
Not sure that I have this posted in the right forum, but....
Old 06-01-2012, 09:22:24 AM
Exclamation Re: 6-71 detroit diesel powered Ingersoll Rand air track drill
have you run the engine under heavy load a while? The engine may be 'wet stacking', incompletely burning fuel due to low combustion heat/cold engine situation. Check the thermostats to see that they are working. A cold engine will not run well. Check compression. Poor adjustments, Low compression due to bad injecter valves, poor ring seal, and or a worn out engine , will also cause fuel to be dumped out the exhaust.
Old 06-01-2012, 11:06:09 AM
Default Re: 6-71 detroit diesel powered Ingersoll Rand air track drill
Thanks for the reply and I'll begin troubleshooting the items you mentioned. This project marks my first old diesel. Could tell me what range the compression should fall in?
Thanks again
Jim
Old 06-01-2012, 06:24:48 PM
Tony Rye Tony Rye is offline
at sea level average new eng.475 min 425 at 600 rpm diesel will not fire at 350psi in most cases this pressure is for a 71 E engine
The Following User Says Thank You to Tony Rye For This Post:
Old 07-04-2012, 10:15:53 AM
Dragline Dragline is offline
Jim, I see you are in Seward and that brings back poignant memories. In December of 1986, we lost a 9299 American, 165 ton capacity crawler crane over the handrail in 400 ft. of water less than half a mile from Seward. It is still there if you want it. It would be very expensive to salvage The operator jumped off which was good for at least two reasons. First he did not get hurt and second he was still alive to get fired! Good luck with your 6V-71, good engine for a 600-750 cfm compressor.
Ingersoll Rand 3-R-36 82f100swb Antique Gas Engine Discussion 6 11-22-2012 05:09:35 PM
Old Ingersoll Rand T30 q240z Machine Shop and Tool Talk 5 09-18-2010 06:02:36 PM
Ingersoll-Rand Spot Air 3-R-36 AlforRay Antique Gas Engine Discussion 2 10-14-2008 10:46:32 AM
Ingersoll Rand L.D. Antique Engine Archives 3 10-21-2002 10:47:22 PM
