Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
BRIGGS NPR6 on Planet Junior
Hello, I'm new to this site. Ok I'm having trouble getting the old girl to fire. It has the float...
this thread has 2 replies and has been viewed 581 times
Old 06-08-2012, 10:22 PM
planter senior planter senior is offline
Default BRIGGS NPR6 on Planet Junior
Ok I'm having trouble getting the old girl to fire. It has the float bowl carb.
I have spark, fuel and I think enough compression. I squirted a bit of oil in the cylinder, turned it over a few times and then let it sat. I get a few puffs and that's it. Then the gas starts to drip out at the bottom of the air intake. I will get a new carb kit but am I flooding it or is it leaking? Had the carb all apart and everything was ok except for maybe a gasket.
Any thoughts?
Old 06-09-2012, 08:48 AM
Coolhand Luke Coolhand Luke is offline
Default Re: BRIGGS NPR6 on Planet Junior
Hi,
General rule of thumb I use is start with a new plug. That eliminates a lot of headaches. Even if fires when outside of the engine it sometimes will not fire under compression. You may be suprised!
Luke
Old 06-12-2012, 03:02 PM
thetractorfreak thetractorfreak is offline
If it has compression and a valve isnt stuck of leaking, have you checked the float needle valve. If the carb has been rebuilt a lot of times a plastic needle valve was used and the ethanol in todays gas is turning them to goo. I have already had 4 of my engines and 7 others peoples engines have that problem
Planet Junior tractor darrin Garden Tractors / Mowers / Scooters 11 07-05-2011 01:08 AM
Planet junior with NPR6 engine ajo Garden Tractors / Mowers / Scooters 2 02-26-2010 07:48 PM
Planet Junior BR6 Briggs engine darrin Garden Tractors / Mowers / Scooters 2 12-18-2008 08:56 PM
Help with Planet Junior Roland Finkenbinder Antique Engine Archives 1 07-19-2004 09:34 PM
planet junior mfg. mike malin Antique Engine Archives 1 10-22-1999 08:42 AM
