Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
New Black Box CD ignition systems
this thread has 25 replies and has been viewed 7636 times
Old 07-19-2012, 12:05:06 PM
CaptainJohn CaptainJohn is offline
Default New Black Box CD ignition systems
I am into both RC airplanes and Model Hit&Miss engines. I have found a very nice CD unit a friend builds and repairs that will work very nice on our stationary single cylinder engines. He makes them for twins also. The one I got from him is a non advance unit that can be powered by 4 double AA batteries or 4 rechargeable Ni Cads. It requires very little power and will run a engine for a very long time. Instant starts ans no points to burn or get oily. Very easy to install with no maitinence required. A dream come true really. Here are some photos of it. Capt,n John Click image for larger version
Old 07-19-2012, 12:18:08 PM
Default Re: New Black Box CD ignition systems
Here is the address for the Guy that builds & repairs the Black Box CD ignition. This ignition uses the same circuit of one of the best units that has been around for may years.
John Weidman
341 Ontelaunee Trail
Hamburg, Pa. 19526
Old 07-19-2012, 09:43:17 PM
Here is John Weidman,s web-site so you can contact him by email.
gr8flyer55@verizon.net
Old 07-20-2012, 05:55:05 AM
deverett deverett is offline
Cap'n John. Which calendar system are you using? Over here in Ireland we haven't yet reached August 2012, but then we always were reckoned to be a bit slow.
(Have a look at the date on your pictures!)
Dave
The Emerald Isle
The Following 2 Users Say Thank You to deverett For This Post:
Old 07-20-2012, 08:28:45 AM
oldproff oldproff is offline
Thanks I will check into this. Bill K
The Following User Says Thank You to oldproff For This Post:
Old 07-20-2012, 12:34:10 PM
The photo of myself by a Model Asscociated Hit & Miss engine has about the same type of CD ignition as the new Black Box but the new CD unit is much smaller and will go into a small wooden box to hide it and you can add a switch real easy. The little wood box is only $1.89 at a craft store. You can get the same box vented or solid top. Pait or stain of your choice. By the way...I have been taking my engine to shows for over 5 years...never had the engine miss a beat & starts Sooooooo good! You can buy rechargeable batteries with a charger for about $10-$12 bucks. I just tested the new unit with a device that plugs into the pick-up lead. It put out very good spark with a crack to it....also nice blue spark. The kind that will really rock ya! Best Regards Capt,n
Old 07-20-2012, 05:07:20 PM
maury maury is offline
Y'all, since we are talking about model ignition systems, I have found you can get the same excellent results with the S&S machine CDI idnition system. I have several engines running in it using 3 AAA cells to power it. THey have not run down after a year now, ( using duracells), and I am convinced as the quality of this system. Easy starts and reliable runs.
The system can be configured as a buzz coil or single spark system, and either configuration can be triggered by just points or by a magnetic pickup. It's also very compact. It's nice to know there are some good options for ignition systems out there.
web site for S&$ machine
http://www.cncengines.com/
maury
Old 07-20-2012, 05:42:14 PM
Harvey Teal Harvey Teal is offline
Will these systems jump a spark in a normal-scale cylinder using a 14, 18, or 24mm plug?
Old 07-21-2012, 09:21:57 AM
Thumbs up Re: New Black Box CD ignition systems
The very high quality and fully repairable Black Box ignition will throw a spark 3/8 too 1/2 inch. There is no reason it will not fire about any size plug. Most of the engines on these fourms are low speed...low compression making it easy for a CD ignition to fire a sparkplug. As a note...this same ignition is used in high reving ....high performance RC airplane engines that got to perform flawless. Capt,n
Old 07-21-2012, 12:17:15 PM
Bob N Bob N is offline
Cap'n John
You said no points, does this use a hall effect to trigger the cdi?
Bob
Old 07-21-2012, 11:37:33 PM
Bob, I refer to this as a Hall type CD ignition. What I do is use install an aluminum ring that fits on crank-shaft with a small 1/8 dia super magnet in the ring. A pick-up sensor is placed close too the ring that rotates with crakshaft. As the magnet passes the sensor it causes the timing for the spark to fire. I use a small set screw to keep the ring in place on shaft. Just loosen set screw to adjust timing. No aluminum ring needed if you have a non steel place to mount magnet. It is very easy too do. Also if you wanted to have a way to advance and retard the spark...you could make a pivit arm to move the pic-up sensor in a arc...so as to make the timing varible. I may need to upload photos. Capt,n
The Following User Says Thank You to CaptainJohn For This Post:
Old 07-25-2012, 03:44:58 PM
Cap'n John
Thanks I was guessing it was a hall type. I am about to try that on
my "May" engine. I have been using a CDI with the points and have had some issues.
Bob
The Following User Says Thank You to Bob N For This Post:
Old 07-25-2012, 07:34:13 PM
Here is the address below.
John Weidman
Hamburg, Pa. 19526
His email is.... gr8flyer55@verizon.net
Old 07-26-2012, 12:28:59 PM
DustyBar DustyBar is offline
The magnet doesn't even need to be attached to the rotating part. You can place the magnet on the stationary Hall pickup. Just make sure the hall sensor is between the magnet and the rotating metal.
Old 07-30-2012, 06:37:56 PM
I will be making a short video of my Hit & Miss engine and how it starts & runs with the New Black Box CD ignition and post it on YouTube. I will post a link here so folks can view it. Capt,n
Old 09-06-2012, 12:00:06 PM
Exclamation Re: New Black Box CD ignition systems
I have been very busy...still intend to make that video. Thanks
Capt,n
Old 10-07-2012, 09:29:00 AM
Well, I made 2 video,s about 10 days ago. I cannot get them to upload to YouTube. I have been very busy too working on my house...getting it ready to sell. I will try to upload the video again. Capt,n
Old 10-18-2012, 02:21:18 PM
This link should work for the test on the New Black box ignition
Thanks for viewing. Capt,n John
https://picasaweb.google.com/1106774...09599272854050
Old 10-18-2012, 09:24:28 PM
Photo Re: New Black Box CD ignition systems
Here is the address for the Guy that builds & repairs the Black Box CD ignition. This ignition uses the same circuit of one of the best units that has been around for many years.
John Weidman
Hamburg, Pa. 19526
Old 10-23-2012, 10:52:11 AM
Question Re: New Black Box CD ignition systems
I have never done a ignition system the way you described. Can you post a photo or more...with more details. Thanks
Capt,n
Ignition Systems Forrest A Scale Model Engineering 2 07-19-2012 09:19:36 PM
Rumely Oil Pull ignition systems Donald J Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 17 06-29-2009 11:12:51 AM
Different ignition systems vern0n Antique Gas Engine Discussion 3 04-04-2009 11:02:52 PM
Model engine ignition systems Kelly Tytlandsvik Scale Model Engineering 2 04-23-2007 10:24:04 AM
Quote about development of ignition systems Leonard Keifer Antique Gas Engine Discussion 2 04-01-2007 03:48:52 PM
