Power Products AH-47 with Fairbanks Morse Rewind
Power Products with Fairbanks Morse Rewind pre Tecumseh buyout 1953?? Another little 2 stroker for...
this thread has 13 replies and has been viewed 1134 times
Old 07-21-2012, 12:08 AM
kammer0072000 kammer0072000 is offline
Default Power Products AH-47 with Fairbanks Morse Rewind
Power Products
Another little 2 stroker for the collection. Simple rebuild. Really like the fact that it has a Fairbanks Morse rewind.
The Following 4 Users Say Thank You to kammer0072000:
Old 07-21-2012, 12:13 AM
Default Re: Power Products AH-47 with Fairbanks Morse Rewind
More Pics
Kinda' nice little motors
The Following 2 Users Say Thank You to kammer0072000:
Old 07-21-2012, 02:06 AM
ehpower2 ehpower2 is offline
those rewinds really are nice till they stop working then its a nightmare
Old 07-21-2012, 10:45 AM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Their neat little engines, I have three of them, all with the same pull start. One of them I removed from a grain elevator. Just like about any air cooled engine Im sure they had a wide range of applications.
Patrick
Old 07-21-2012, 12:19 PM
I think they are a really well made rewind. I completely tore it down and found it very easy to work on and to replace the cord. A heck of a lot easier than say a briggs rewind that is welded to the shroud. It also cool that it can be configured to work in either direction as the dogs are reversible (CW or CCW).
Old 07-21-2012, 01:41 PM
K-Tron K-Tron is offline
Kammer, those are some beautiful AH47 engines.
What kind of paint did you use on them to get that nice finish?
I have been using plastikote and VHT but both come off when fuel is spilled.
While we are talking power products, Do any of you guys have any AH 36 parts?
I bought some "AH36" parts on ebay and they turned out to fit an AH47.
I am looking for a good cylinder, piston and rod for my 1959 Rowco Brushking. I have a good cylinder/piston and rod for an AH47 to trade.
Thanks,
Chris
The Following User Says Thank You to K-Tron:
Old 07-21-2012, 01:45 PM
Its where the dogs dig into the cup then its the nightmare as the cup wears out and dogs dont catch. Jb weld wont fix but welding up will
Old 07-21-2012, 05:55 PM
I can see where that would cause problems. A guy could try and sleeve it somehow. Thankfully, mine works great. As for paint, I use dupli-color. Gas won't touch the silver.
Old 07-21-2012, 07:39 PM
GADavis GADavis is offline
Simple fix for the dogs not catching. Put the dog ear in a vise and squeeze it a little and that will make it a little longer. Be careful you don't squeeze too hard as they will break. Worked in the lawnmower/ chain saw business fir about 15 years and Homelite loved these dxxn recoils as did many off breed brands of saws, Gene Davis
Old 07-21-2012, 10:00 PM
Edward Cole Edward Cole is offline
The A H 47 engine was used a lot in chain saws
david bradley, mono,strunk lots of others .
The F M starter is a great starter good to work on. Change the 2 fiber washers in the center , new rope & the timex keeps on ticking Those fiber washers are still available at your local stihl saw shop .
Old 07-22-2012, 01:59 AM
Ya i knew about that trick my worry is if you break the dogs where do you get replacements if they weak to begin with
Old 07-22-2012, 03:02 AM
oldschoolwisconsin oldschoolwisconsin is offline
Thanks,
Chris
The paint could be aviation paint. Because aviation engine enamel is fuel resistant. Thats what I used on my AHH, cept its painted Lycoming Gray.
Old 07-24-2012, 11:38 AM
Exclamation Re: Power Products AH-47 with Fairbanks Morse Rewind
The early Power Products engines used a wrapa rope starter. The F/M starters were sold as an after market option. They werre easily mounted, and worked well. When I was a kid, the mower shop I worked on had cases of these starters, New Old Stock. The new owner sold them for scrap, back in the 1970s. Wish I had kept a few. The art work on the F/M boxes was neat! Yellow and black background, red print and a large white F/M logo on the top of the box!
Old 07-26-2012, 06:43 PM
ryan68bug ryan68bug is offline
I've got an AH36 that I acquired recently... plan to use it on a vintage look-a-like kart or minibike project, hopefully. Pics are attached. Mine has a flat gas tank, though.
Power of the Past Vol. 2- Fairbanks-Morse Zira Antique Gas Engine Discussion 1 03-28-2009 03:13 PM
Fairbanks Morse Power Plant Chris J Antique Gas Engine Discussion 18 12-27-2007 09:08 PM
Vintage Fairbanks Morse Power Plant Harry Generators & Motors General Discussion 3 11-29-2004 10:22 PM
Fairbanks, Morse Rewind Starters Bill Sherlock Antique Engine Archives 1 11-26-2004 08:56 PM
Power Products / Fairbank Morse? David Greenwalt Antique Engine Archives 5 09-14-2003 08:41 PM
