Preservation Methods for Original Finish
Saw a post below that alluded to methods of maintaining/enhancing the original finish on the old...
this thread has 19 replies and has been viewed 4907 times
Old 10-23-2003, 09:14 AM
Baggsy-Wy
Default Preservation Methods for Original Finish
Saw a post below that alluded to methods of maintaining/enhancing the original finish on the old engines. I saw in the archives where linseed oil could be painted on, but other than that I can't seem to find much. What might some of the other methods be and what is the best? Looking forward to another long winter in the shop...Baggsy
Old 10-23-2003, 12:14 PM
Bruce Wambach
Default Re: Preservation Methods for Original Finish
Baggsy,
I have left all of my engines with the original finish. First they are cleaned with kerosene and left to dry. Then I apply a 50/50 coat of boiled linseed oil mixed with mineral spirits. It is important to have 50% mineral spirits because straight linseed will leave a sticky finish. You will be surprised of the result with an engine that appeared to have no original paint left when you started. The kero is key to the cleaning process. Let me know how it works out for you.
Bruce
Old 10-23-2003, 02:17 PM
peter
Default Nothing works for me.
I like to leave them origional with nothing on them. Less work for me and protects my investment as there is no risk of future collectors wanting origional, un enhanced finish.
And Thats also the way I like to aquire them.
FWIW
Old 10-23-2003, 03:25 PM
Vernon
Default Re: Nothing works for me.
I tried the streight linseed oil. It took a long time to not be stickey. Other things that don't work are; saran wrap, lamination, imbedded in polyurathane, and having it bronzed. I hear clear coat works, but may yellow with time.
Old 10-23-2003, 05:21 PM
Lester Bowman
In 25 years of restoring these wonderful old engines my concept has changed from "creating the beautiful" to "preserving a character". Preservation of character is done slowly.You begin by documenting the engine.(if possible) When and where was it used? Original owner? What did it do? How did the seller aquire it? Statement # 1.Lose the original history of the engine when you had the OPPORTUNITY to preserve it translates into idiot. I clean engines in various ways but always gently.Soft brass bristle brushes used around detail parts wont scratch paint.Use plenty of kerosene when cleaning dried grease & oil.Steel brushes can be used carefully to clean larger areas while wooden scrapers can be made to rub off softened residue. Dont rule out hot water and washing detergent to make the initial cleaning.There is information on Harrys site alluding to these cleaning methods.Go slow,preserve what remains of original finish.
When its clean,THEN begin disassembly.Clean each piece as it comes off.Keep assemblys together.Think about what your doing.Observe the craftsmanship as elbow grease reveals past skills.Appreciate the file marks and specks of paint.Note the iron filler,let your mind go back. Do the mechanical repairs to duplicate the old look.NO cadmium nuts or washers.No bolts with modern markings.Perform all the aspects of a sound mechanical restoration while maintaining the integrety of age and history. Fire it up and listen to it!Beautiful,Isnt it? No? Well,it is to me. Now I am speaking in terms of an engine with oh say,20% or more original finish.At this point I would spray it down with something like John Deere multi-purpose lube or WD40 rubbing it in with a soft cloth.Do that once or twice a year and after a year or so,the cast with take on a lovely dark patina while the paint is preserved.No,The paint wont be glossy but protected.I also like the look some guys achieve using a clear coat but sometimes this can be too glossy.The suggestion in the previous post says lindseed and turpentine works well but is slow drying.Use BOILED lindseed and increase the turpentine ratio.This works nice too but is difficult to remove if required. From this point on enjoy and feel proud of your work for you have preserved the character of a piece totally dependent opon you for its character survival. Go ahead,Sandblast the boat anchors and paint the welded up engines or the engines made up from a dozen others just like it.These already have lost character patina.Anything will be an improvment. Statement # 2.An engine in good unmolested original condition cannot be made more valuable by ANYTHING we do to it excepting maintaining its character as I have lined out.IN other words the most expensive paint in the world can only decrease its value. Just an opinion guys.These engines stand on their own and always will as long as we protect them.OK! I'm ready for ya,eat me alive!
Old 10-23-2003, 05:35 PM
Doug Wilson
Lester, I'm behind you 110%. Doug.
Old 10-23-2003, 06:08 PM
Kid Dynamo
The Fairbanks 3hp ZC I bought came on original wood skids with original paint, but had suffered numerous paint spills and splashes.
The spills and slops came off with vigorous scrubbing, but this injured the gloss on the paint.
After consulting the archives, I branched out a little and used a couple of wet coats of "Penetrol" additive for oil based paints. It is a multi-use product. It dries overnight, ordinarily.
My results are good. The gloss is evened out and where paint was dried and flaking from the wood skids, this appears to have knitted things together, as if the remaining paint is holding and the "bare" wood looks like it has a coat of semi-gloss varnish. The gloss is a bit more than I suspect the paint originally had but not overwhelmingly so.
I am very glad that I chose this route for this particular project. On another project, a trial area could be evaluated before committing to the whole engine, etc....
Worked for me, that day.....
Old 10-23-2003, 09:16 PM
allen lapage
Not trying to stir the pot too hard, but I cannot say I personaly agree with leaving A engine as found with only 20 or 30% of its original paint remaining. Unless it is A very rare engine or with A speical history. I have been involved in many types of collecting, motorcycles, cars, ect. but cannot recall another hobby where 30% of the original finish was better than correctly restored. Not even farm tractors. Now lets be honest here. How many of you would buy A Studibaker golden hawk and completly re-do the eng, trans, wireing and so on and not do any body work, upolstry, or paint it. Then take it to A show and expect any one to even look at it. Thats not how it came from the factory now is it? Just my personal opnion but to each their own.
Old 10-23-2003, 09:29 PM
Lester Bowman
Sorry you misunderstood allen,My point is with one lung antique farm engines with flywheels,spark plug or igniter fired with water hoppers and cooling tanks.NOT old cars,motorcycles or tractors.
Old 10-23-2003, 09:37 PM
Tim
I believe comparing cars to antique farm engines are like comparing oranges to golf clubs. Just my opinion, but everyone has the right.
Old 10-23-2003, 09:43 PM
john willis
Well, I have been thinking of posting something along this line for a while anyway, so here goes. I personally like an engine that is fixed up and restored to original condition. I'm not great at it, but I try. I can see the other guy's point as well. It is interesting to see how these old engines have survived the years. I guess my thought is, if it's your engine, fix it up the way you like it and enjoy it. Buttttt there is one thing that yanks my chain real hard. That's somebody that takes an old greasy engine and paints right over everything. I am working on one right now, and yes I knew it was like that when I bought it. 90 year old grease is hard enough to get off anyway. but try it with 6 layers of 98 cent Walmart paint on top of it. I have tried every tool known to man to get this thing cleaned up. It's enough to drive a man to drink.
Old 10-24-2003, 10:36 AM
Matt Fretwell
Hello all,
Just to put two pence worth in. At the end of the day, it's a pure and simple case of whichever method you prefer. I personally like to repaint a unit, not necesssarily even original colours, but at the end of the day, it's for your own personal benefit, no one else. It's your unit, you are the person who sees the beauty in it, so whatever makes that person happy. As long as it is protected from decaying any further, finish is irrelevant. And just to get back to the original post, pretty much anything oil based will protect and bring a lustre to a finish.
Old 10-24-2003, 06:51 PM
Harvey Teal
I have seen too many engines painted up to conceal cracks, welds, and other damage covertly. I have even been blind enough to buy such engines, completely trusting the seller's word that the engines had no damage. So I personaly don't buy painted engines anymore. But I really do appreciate the time and pain that many owners put into beautifully refinishing their engine. And, hey, if they want to disguise cracks, welds, and blemishes on their engines when refinishing, that's okay. Why spend the time, energy, and money if the job isn't going to look good?
Old 10-24-2003, 07:08 PM
John Rolli
The only thing I would like to add to this thread is this. They are original just ONCE. Think about it.John.
Old 10-24-2003, 09:23 PM
David Greenwalt
This is for amusement only, since we all know what we mean when we talk about something being original. Definition below is straight from the dictionary. According to this definition if you want to have something to really, really think about, then the only true original engine is the very first one made, the rest are all copies. So technically, since all we have are copies I think everyone should send their copies to me for proper disposal and go out and look for an original one. I'm willing to take on this burden to save everyone the embarrassment of unintentionally showing a non-original engine that you may have worked months, or even years, on.
Main Entry: 1origˇiˇnal Pronunciation: &-'rij-&-n&l, -'rij-n&l Function: noun Date: 14th century 1 archaic : the source or cause from which something arises; specifically : ORIGINATOR 2 a : that from which a copy, reproduction, or translation is made b : a work composed firsthand 3 a : a person of fresh initiative or inventive capacity b : a unique or eccentric person
Old 10-25-2003, 12:17 AM
Walt in Jaxn Tn.
Old English furniture polish, Liquid Gold furniture polish. All my engines (grand total of 4) were repainted when i got them, so I will not have the opurtunity to worry about origional finishes---------Walt
Old 10-25-2003, 04:27 AM
BobRR
This is how I approach this. If the engine still has some original paint. Clean it and give it a coat of some kind of protectent. (I have had good luck with boiled lindseed oil.) If no or little paint and runs good leave it alone , if little or no paint and needs to be tore down, clean and paint close to factory color. I dont like painting what ever color is handy even though it is better then letting them rust if stored out side.(personly I would rather clean up the rust than have to strip off some weird color!) but if showing we should try and represent what they looked like from the factory! We are trying to preserve and teach the history of these old engines are we not? BobRR
Old 10-25-2003, 11:38 AM
Matt Fretwell
Judging by the last definition of originator that was posted from the dictionary, (or eccentric person), it's probably safe to say that everyone here are more original than their engines, as eccentric seems to be a kinder way of saying what the wife calls me!:-)
Will also say that beeswax does make a lovely finish/protectant, but obviously doesnt cope well with heat.
Matt
Old 10-25-2003, 08:39 PM
John Rolli
My 1937 Websters dictionary has that plus this also. 1.of or pertaining to the origin or beginning;first in order or existance,primitive; pristine, 2. NOT copied,imitated or reproduced;new firsthand 3.Independant or creative in thought or action.inventive. Still hits the nail on the head of an engine that has not been estheticly refurbished since new. John.
Old 10-26-2003, 11:17 AM
Keith Smigle's Avatar
Keith Smigle Keith Smigle is offline
Hello All~
Dr. John Wilcox (One of the original founders of the Cool Spring museum) uses nothing but Auto Trans Fluid on all of his engines. This includes his Callahan, 125HP Otto, 150HP Miller and many others. And just like a previous post stated about WD40 I believe after a while a nice patina is developed. All of his engines look outstanding. I have been using WD 40 but I am going to get a spray bottle and start using ATF exclusively my self.
~Keith Smigle in Delaware, oHIo
Removing paint to get to the original finish Brian Lynch Paint Shop 1 12-25-2006 10:01 PM
Linseed Oil Finish Walt Beeman Antique Gas Engine Discussion 4 07-07-2006 10:33 PM
original paint finish Garrison Brown Paint Shop 7 01-22-2003 04:14 PM
Painting methods? Bill Blackburn Antique Engine Archives 2 12-26-2002 07:36 PM
Original Mag Finish??? Bill Nich Antique Engine Archives 2 12-26-2000 07:16 PM
