Fairbanks Morse 32E 80hp Single Cylinder
this thread has 34 replies and has been viewed 4778 times
Old 09-07-2012, 08:42:34 PM
James Hill James Hill is offline
Default Fairbanks Morse 32E 80hp Single Cylinder
I am working on restoring a model 32E single cylinder 80 HP FM engine for our club. I am very close to getting it running except for I am missing one part. In my original book, It shows the part being the air start distributor FM part number 4596. It uses 4 bolts and mounts on the side of the cylinder head. I am also missing the top water outlet pipe that mounts on the top of the head and goes down to the air start distributor. Any help in locating these parts would be greatly appreciated!
I will show some pictures shortly.
James
Old 09-07-2012, 08:47:53 PM
James
The serial number of this engine is 793479
Old 09-07-2012, 10:49:37 PM
DirtbikePilot DirtbikePilot is offline
Default Re: Fairbanks Morse 32E 80hp Single Cylinder
No offense, but the most horsepower a 32E puts out per cylinder is 75.
Old 09-07-2012, 11:02:12 PM
The person prior to me told me that it had a big bore kit put into it but I'm not sure if it's true or not.
But yes I agree with you on the 75 hp.
Old 09-08-2012, 03:50:32 AM
J.R.Smith J.R.Smith is offline
Build your own! Not hard to do on a single. I built the one on Big George, 120 hp YVA. The old one was in bad shape. It had Hard water in it. I will see if I can post a picture, later J.R.
Old 09-08-2012, 08:51:11 AM
Sounds great JR! I was thinking about building one but I wasn't sure if there is supposed to be some kind of check valve in it. This is my first fairbanks engine build.
Old 09-09-2012, 11:49:06 PM
Here are some pictures of the current project.
Old 09-10-2012, 12:00:01 AM
Here is where the missing piece goes.
Old 09-10-2012, 07:38:22 AM
Actually this part is called an air start distributor. It is a small manifold that allows air to enter into the cylinder for air starting.
Old 09-10-2012, 09:03:20 AM
The Check Valve is in the Head. J.R.
The Following User Says Thank You to J.R.Smith For This Post:
Old 09-10-2012, 10:12:53 AM
Ahhhh ok. Is it the piece between the 2 larger bolts on the head? And Does air run into both of the ports?
Old 09-10-2012, 11:39:51 AM
No. 1 is Air and 1 is water. I will try to get some pictures posted for you. J.R.
Old 09-10-2012, 02:11:37 PM
Heins Heins is offline
This is what my air distributor looks like on my 40 horse.
The Following 2 Users Say Thank You to Heins For This Post:
Old 09-10-2012, 06:29:20 PM
I can only get 1 picture to upload. The Top hole is cooling water. The bottom hole is for the Air Start. The Air Distributor body is on the back side of the Fuel Reservoir and Fuel Injection pump housing. J.R.
Old 09-11-2012, 07:47:37 AM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
James, JR Smith sent me these pics to upload. His computer is not playing nice. His home made manifold works very well. I will be at his place in a few weeks and can take more pics if you need them.
Dwayne
The Following User Says Thank You to Dwayne Fuller For This Post:
Old 09-11-2012, 08:09:11 AM
I posted two pics Jr sent me on your other thread about the 80 hp.
Old 09-11-2012, 08:38:25 AM
Thumbs up Re: Fairbanks Morse 32E 80hp Single Cylinder
James, the 1st picture is the AIR Distributor Body, part# YKA4596A. It was used on Many Models FM Engines in 1 and 2 cylinder engines both 12 & 14's. It bolts on the back of Injection Pump, Fuel Reservoir & Governor Housing. Not the Head. The Air Starting Pipe starts at the Air Distributor and goes up to the head to the Water Manifold and into the head. Parts are hard to find. Hard Water got most of them. The rest went to China. Good Luck in your Quest. Build your own, get the engine running and keep looking for the parts that you need. I gave up on finding the parts. My 120 hp runs great like it is. Hope this helps a little. J.R.
Old 09-11-2012, 08:50:30 AM
I would like to thank you guys so very much for your help and expertise! This is going to make this engine run! I am going to go ahead and make up that piece. Then all I need to do is run the fuel line, check out the governor, and see what happens! I will definitely stay in touch and I will be sure to post a quick video when I get her up and running!
Old 09-11-2012, 09:39:39 AM
I think this is the manifold that bolts to the head on my 40 horse. With JR's help, maybe I will figure out where all the pieces go. I need to get to work on "Ive".
The Following 3 Users Say Thank You to Heins For This Post:
Old 09-11-2012, 10:35:49 AM
That is def the piece I need! I will make a temporary one to get it running and then maybe I will get lucky enough to find one someday. Also, about the fuel line. I had someone tell me that it has to be an exact length and diameter for the pump and injector to work properly but on every Fairbanks engine I have looked at, they all just had a copper line. And as far as the multi cylinder engines would go, this would seem impossible. Does this seem right?
3 cylinder and 2 cylinder Fairbanks Morse Diesels Randy L Peterson Vintage Diesel and Oil Engines 0 09-14-2011 01:23:46 PM
Fairbanks Morse Cylinder Head Spenser and Dave Rynne Antique Gas Engine Discussion 7 08-25-2011 06:42:36 AM
Four cylinder Fairbanks Morse 200 hp skiwithnoskis Multi-Cylinder Stationary Engines and Power Units 3 07-18-2010 05:15:38 PM
Fairbanks Morse Model 45 - Single Cylinder Diesel Ted Rozanski Antique Engine Archives 0 07-29-2002 01:11:32 PM
Two Cylinder Fairbanks Morse Larry Kastens Antique Engine Archives 0 02-17-2001 11:13:43 PM
