Onan Marine Genset 6.5 MCCK Series F
this thread has 4 replies and has been viewed 1237 times
Old 09-11-2012, 09:45:46 AM
grameric grameric is offline
Default Onan Marine Genset 6.5 MCCK Series F
I have an Onan Marine Genset 6.5 MCCK Series F and I am having a problem with it shutting down when I put a load on it. It has a new carburetor with maybe has 3 hours on it. If I play with the load switch a couple of times and it goes through the initial spike, then it works fine. Does anybody have any suggestion? THanks.
Old 09-11-2012, 01:30:52 PM
Default Re: Onan Marine Genset 6.5 MCCK Series F
It seems like the load hits, the governer open the throttle and it dies.
It could be due to the main jet being too lean or the gas is bad.
The Following User Says Thank You to sdowney717 For This Post:
Old 09-11-2012, 07:44:08 PM
Why was the new carb. installed? Does the governor open the throttle all the way to the stop when the load hits it? Can you keep it going with a shot of carb. cleaner in throttle body when it starts to bog down? These questions all relate to fuel problems or throttle, how much of a load are you putting on it when it dies (total amps)?
The Following User Says Thank You to Max Thompson For This Post:
Old 09-11-2012, 08:13:31 PM
Billy J Shafer's Avatar
Sounds like it is overloaded. If you are having to bump start the load.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 09-12-2012, 01:58:17 PM
I know for a fact the gas is not bad. I am going to try and adjust the carb and see how it goes. The carb was replaced because it sat for a long time and I found a new one for the price it would cost me to rebuild. As far as the governor I haven't checked. I will need a second pair of eyes for that, I will try this weekend. I don't know the exact amps on the load I tried, but it would do it even starting the coffee maker. Thanks for the input guys.
Onan 6.5 MCCK marine spark plugs? koviak Onan Generators 8 03-23-2012 06:50:28 PM
Onan MCCK 6.5 G Series Choke Tasharue Onan Generators 1 01-09-2012 04:34:29 PM
1984 Onan 6.5 mcck series h with oem electronic ignition will not start. Burmik Onan Generators 0 01-09-2012 09:26:17 AM
Onan marine 6.5 MCCK carb adjust mxgeezer Onan Generators 9 08-16-2011 01:04:23 AM
MCCK Onan Marine...Running Rough GlobalEnergies Onan Generators 1 05-30-2007 09:41:59 PM
