Older kohler gen runs rich
I have a 4.0 BF - 3CR/16004B generator that came out of a motor home. I think it is mid 79s. I...
this thread has 9 replies and has been viewed 858 times
Old 09-11-2012, 10:10 PM
Chieffox Chieffox is offline
Default Older kohler gen runs rich
I have a 4.0 BF - 3CR/16004B generator that came out of a motor home. I think it is mid 79s. I had it running well although you had to always "play"with it to get it started. Now it may start but runs like crap, popping and banging and seeming to run rich. What should the settings be on the two needles at the base if the carb, anyone know? Anything else I should be looking for?
Old 09-12-2012, 09:11 AM
Kevin K Kevin K is offline
Default Re: Older kohler gen runs rich
That's an Onan generator, not a Kohler. If you post the serial number, we can give you the date it was made.
You might consider moving this post to the Onan forum for a better response.
To answer your question, the initial adjustment for both the idle and main needles is 1 1/4 turns open.
You might also check the float level, 5/16" +-1/32", and the choke adjustment.
Old 09-12-2012, 08:02 PM
Ken86gt Ken86gt is offline
Is the gas fresh?
Old 09-14-2012, 04:31 AM
lokay5 lokay5 is offline
Talking Re: Older kohler gen runs rich
What's a Kohler?
Old 09-14-2012, 08:15 AM
MBB MBB is offline
They make toilets.
The Following 2 Users Say Thank You to MBB:
Old 09-14-2012, 08:56 PM
PnishrPW PnishrPW is offline
And faucets...
Old 09-14-2012, 10:44 PM
GHanners GHanners is offline
the bold new look !
anyway poping running rich check the valves & points & cond
The Following User Says Thank You to GHanners:
Old 09-15-2012, 06:37 AM
Gunny Gunny is offline
Kohler makes a fine genset, on par with, and in some cases, especially with the new stuff, of a better quality than Onan.
Popping noise? Look to the ignition system. The correct spark plugs? Correctly gapped? Ignition timing right? Points in good condition? Gapped right? Choke opening when warm? Then look to carburation.
The Following User Says Thank You to Gunny:
Old 09-15-2012, 06:44 AM
..............................Ah ha ha haa !
"They make toilets."
That really cracked me up!
Thanks MBB!
Old 09-19-2012, 08:57 PM
Thanks all. Driving me crazy as it will run nice and smooth for hours or sometimes only minutes the way it should and then just start banging and popping and smelling rich. Put in new plugs, seemed to be good spark. Anyone know the correct gap? Guess I'll play a little more and see what I can do.
Thanks again.
my Kohler 10 kw runs.... c east Kohler Generators 41 08-25-2011 07:47 PM
My Kohler Runs K D Redd Kohler Generators 0 08-15-2011 09:01 PM
Kohler Model D Manual, Older (1923-25) Rusty Fingers Kohler Generators 14 11-15-2005 10:58 PM
Older Kohler Help Wanted Steve A Kohler Generators 0 06-12-2005 08:32 PM
