Kohler Generators
voltage regulator question
this thread has 3 replies and has been viewed 1407 times
Old 09-19-2012, 11:44:17 PM
mongoose969 mongoose969 is offline
Default voltage regulator question
has anyone measured the output voltage to f1/f2 fields on 6 ohms slip rings 4kw genset when running at 120vac no load?
Old 09-20-2012, 07:59:47 AM
BergmanJ BergmanJ is offline
Default Re: voltage regulator question
Please provide full / complete Model, S/N, Spec. number; so that the Kohler gurus can actually help you.
Regards, JLB
Old 09-20-2012, 07:43:39 PM
LWB250 LWB250 is offline
No one can tell you because there is no spec for it. If you measure the rotor resistance, which can really only be done accurately with a Wheatstone bridge, you could use Ohm's Law and figure out a rough value, but that's far too much effort to expend.
Long story short, if the engine is running at speed and you put 12VDC to the fields and all is well, you should see at least 40-50 VAC output on a single (120V) winding. Depending on a lot of variables that voltage could be even higher, and often is.
If this is the case, everything from the brushes to the windings are in working order.
Dan
Old 09-20-2012, 09:06:25 PM
len k len k is online now
It's not a Kohler, but for what it's worth, on an Onan 7NHM with electronic regulator the voltage to the rotor varies from 18 to 60VDC into a 20-25 ohm rotor.
On my Onan when I put 12VDC to rotor I got ~45V out the 120VAC leads (with 60 watt bulb).
And............when I put 24VDC to rotor I got ~100V out.
Sliprings and Voltage Regulator Question - resurface and retrofit. Freefall Doug Generators & Motors General Discussion 7 09-02-2011 07:04:22 PM
Voltage Regulator Question Mike Sp Onan Generators 5 03-09-2011 11:45:09 AM
Basler Onan Voltage Regulator Question David Babbitt Onan Generators 31 09-07-2010 04:22:00 PM
Help with Ext. voltage regulator JHFoster Small Air Cooled Gasoline Engines 11 05-25-2009 02:05:05 PM
DJE/YD Voltage Regulator Question B.Ikard Onan Generators 5 01-19-2008 10:04:51 PM
