Missing Stover Timing Mark
this thread has 3 replies and has been viewed 913 times
Old 10-03-2012, 07:43:53 PM
Ed Stoller Ed Stoller is offline
Default Missing Stover Timing Mark
The timing mark on my Stover CT 2, Hit-Miss, S/N 233953 is missing. Using the key way, I have marked TDC on the outer rim of the flywheel and need to measure back from that to make a new mark. If it is about 40 Degrees that is about 6 inches. Could someone who has a good original timing mark please measure the distance in inches between the timing mark and TDC. The circumference of my flywheel is 53.7 inches. Dividing 360 degrees by 53.7 inches is 6.7 degrees per inch.
Old 10-03-2012, 08:16:54 PM
Henry Macomber Henry Macomber is offline
Banned
Default Re: Missing Stover Timing Mark
Ed,
I think your getting a little to technical, If these engines are out a little they will still run. It's good having them as close to dead on as you can, but as I said if your a little off it should still run. I've attached a couple charts I got from David Lyons, he had them posted and I printed them to help a newbie.I hope they help, just remember to time your exhaust first.
The Following 2 Users Say Thank You to Henry Macomber For This Post:
Old 10-03-2012, 08:41:05 PM
Thankyou Henry. That is exactly what a I needed and a bit more.
The Following User Says Thank You to Ed Stoller For This Post:
Old 10-03-2012, 08:42:25 PM
BigGoomba's Avatar
BigGoomba BigGoomba is offline
I dont have my Stover anymore but I do remember that when using the timing marks, it would fire a good distance before top dead center, right around 10 degrees or slightly more before top dead center. After I put a lighter spring in the governor so it would run slower, I changed it so it was firing right at 5 degress before TDC and it was running really well. It would fire and run up to about 400 rpm and then slow down to about 300 rpm before firing again. The original governor spring was really stiff and the engine ran really fast. I didnt like running it until I got it slowed down then I loved it.
It kept my driveway nice and lubricated
-Steve J
IHC LA 3-5 Timing Mark please help no spark Antique Gas Engine Discussion 9 03-11-2011 09:21:31 PM
Wisconsin Timing Mark telmore1964 Wisconsin Engines 2 09-30-2009 01:16:58 PM
No timing mark on crank? gruby26 Small Air Cooled Gasoline Engines 19 06-19-2009 08:09:35 AM
IHC 3HP M crank gear timing mark Help.... mrkimball Antique Gas Engine Discussion 6 09-25-2006 11:23:20 AM
Alamo timing mark Greg Dills Antique Engine Archives 3 11-30-2003 10:35:03 AM
