Lister LD1 Dunlite Generator
this thread has 3 replies and has been viewed 2114 times
Old 10-11-2012, 07:02:42 AM
Acco1982 Acco1982 is offline
Default Lister LD1 Dunlite Generator
Hi all i have just purchased a lister 1956 LD1 fitted with a Dunlite 40volt 35 amp generator i'm chasing any information especialy wiring diagram. any help would be exelent
cheers Alan
Old 10-11-2012, 09:26:39 AM
Default Re: Lister LD1 Dunlite Generator
Looks like a charging set for a 32v home lighting plant. Do you have the switchboard panel that came with it? Probably has a couple of knife switches, fuses, volt and amp meters, a reverse current relay and a charge control rheostat. If so, the terminals will be identified on gen and board, and it's a matter of connecting like with like, plus line and battery connections.
You will need some sort of a control board with at least a reverse current relay (cutout) and a rheostat to operate it, but a board from another 32v plant could be adapted. A heavy diode can replace a reverse current relay if needed. Someone else here may have info to identify connections on your genny. Do the terminals have any markings? Quite a tidy looking unit you have.
32v gear is a bit thin on the ground now, but bulbs I think are still available at a price. You can charge three 12v batts in series (36v) OK, and run groups of 12v lamps, halogen downlights etc, in series, or any other incandescent 12v lamps of equal wattage. Sounds like a nice project. Combustor.
Old 10-12-2012, 08:39:41 AM
Unfortunatly no control panel came with it, if anyone has a pick of a control panel would be a good start. For the money i paid im more then happy with what i got.
as for the terminals they are marked 1 thru 6, as for 32volt stuff i am keeping an eye on a Pope washingmachine to start with but will be keeping an eye out.
Cheers
Old 10-14-2012, 08:14:35 AM
E27N E27N is offline
Hi Alan this is the best I can do at the moment
from left to right across the FRONT of the panel the terminals are 3 6 5 direct load batt common common common 2 4 1
Hope that helps some what I haven't had the set generating power but, I assume that because it sat for so long i may need the fields flashing to remagnitise them but as i dont know which terminals they are I haven't touched her for a while.
Lister hr3 as a generator Edevalco Vintage Diesel and Oil Engines 1 10-04-2011 11:01:03 AM
Lister 12/2 30kw koler generator head COOLING The Lister????? mytickets Vintage Diesel and Oil Engines 2 04-12-2010 04:34:18 PM
Dunlite 32V genset Questions E27N Generators & Motors General Discussion 8 11-24-2009 07:15:22 AM
Dunlite 5000 UPHawkeye Onan Generators 3 05-20-2009 08:44:54 AM
Lister generator B. K. Lahey Vintage Diesel and Oil Engines 0 10-11-2008 05:17:45 AM
