Rewiring an onan 6.5kw RV generator ofor portable use
this thread has 2 replies and has been viewed 1547 times
Old 10-19-2012, 12:40:39 PM
thaddeus333 thaddeus333 is offline
Default Rewiring an onan 6.5kw RV generator ofor portable use
I am trying to wire the output ac wires for portable use. I have a few questions that I could use some help with:
1. I have the 3cr unit so I have 4 output ac wires. It is currently set up with 2 ran solo and then 2 bound together to form a 240 output. Can I unbind the 2 ac wires to form 4- 120V outputs?
2. How do I rewire it? Do I simply run the the ac wires to a breaker box? How do I ground the unit if there is no rv to ground to? Can I use the generator body as the ground? Do I simply run the green ground wire(located in the ac output box)to the breaker box as well? Then do I just run each AC wire to breaker of its own? Or can I simply run a single 15amp GFI per AC wire and run a grounded bus bar?
Any help is greatly appreciated. Thank
Old 10-19-2012, 01:56:54 PM
John Ward John Ward is offline
Default Re: Rewiring an onan 6.5kw RV generator ofor portable use
I would suggest combining your posts for continuity of discussions.
6.5 NH-3CR/16004P (1985)
The Following 3 Users Say Thank You to John Ward For This Post:
Old 10-19-2012, 08:33:17 PM
Wiring diagrams should be printed on the back of the junction box cover. The service manual & the UN generator manual will also have the information you need. If you do not have the manuals, post the complete model & ser. numbers along with an e-mail address & one of us will send them to you.
The Following 4 Users Say Thank You to Max Thompson For This Post:
Rewiring a 4.0 Onan CCK for 240? crotchrocket81 Onan Generators 7 10-23-2013 12:37:25 PM
Generator rewiring question Dieselfan Generators & Motors General Discussion 12 01-29-2012 02:28:57 PM
Rewiring Generator from 230v to 110v JaimeRusso Generac Generators (SEARS, etc.) 6 01-12-2011 10:03:24 PM
MEP 4-7 Generator-Rewiring to Delta B.Ikard Military MEP and Aircraft Gen-Sets 6 02-25-2010 01:02:55 PM
Rewiring Onan Gen Set Cruiser Generators & Motors General Discussion 7 02-15-2010 09:59:18 PM
