I HC ignitor
this thread has 2 replies and has been viewed 988 times
Old 10-24-2012, 04:39:56 PM
overdriver overdriver is offline
Default I HC ignitor
hi folks
i am trying to get my ignitor
first functioning
then rebuilding it ( it was dissembled before i got engine)
please excuse fuzzy pictures
what is the taped hole for on the side of casting ?
the small hook ,i believe goes under the round bar ?
then once it is assembled the points gap should be 1/16 correct
what would you lube the trips with ? (anti seize ,graphite Click image for larger version
ONCE assembled correctly
I will copy all pictures print save
and never let anyone futz with it improperly AGAIN !!
thank you for any insight
Old 10-24-2012, 06:46:06 PM
Default Re: I HC ignitor
The tapped hole is either blocked off with a 1/8" pipe plug or a priming cup goes in it, priming cup: A cup atop of a valve. Pour a dab of gas in the cup, with the engine on the back stroke, open the valve and suck the primed cup of gas into the cylinder. Close the valve off and you've in essence, choked the engine for starting. Pictures are fuzzy, might help if you mention what size engine it's on. Looks like a small I.H. engine.
The Following User Says Thank You to Pat Barrett For This Post:
Old 10-27-2012, 12:40:24 AM
yes it is a 1 Hp
I H C famous
i will have to look deeper in to the hole
as it lookes plugged to my old eyes
I love the idea of a primer cup for it
(if it feeds to the combustion chamber )
ignitor 303 m1 Lonnie Grissom Antique Gas Engine Discussion 1 04-13-2012 03:33:05 AM
Removing Ignitor springs on F/B headless Ignitor Bob Johnson Antique Gas Engine Discussion 1 07-21-2008 06:42:45 PM
Ignitor What Does This Fit? Lauren Antique Gas Engine Discussion 2 12-06-2007 01:19:40 AM
IGNITOR ??? Lauren Langdon Antique Engine Archives 2 08-17-2004 04:23:54 PM
Ignitor Mike Inglis Antique Engine Archives 1 11-15-2002 03:08:59 PM
