Need diagram to wire in a Prestolite TCA 4004 I want to add in the 2 stage regulator
this thread has 3 replies and has been viewed 1555 times
Old 12-01-2012, 09:15:54 PM
Motorhead's Avatar
Default Need diagram to wire in a Prestolite TCA 4004 I want to add in the 2 stage regulator
I want to add in the 2 stage Prestolite TCA 4004 regulator to my later CCK. I have the regulator but need a diagram on how it is wired. Three terminals on the regulator. BATT, B, and last tab is not marked. I looked in the wiring schematics and couldn't see exactly which wire went to which tab. Any help appreciated. I am going to try it with the large three tap resistor. I have two leads coming from the large charge resistor now. One is the 1-1.5 amp charge lead and the other is the 4-5 amp lead.
Old 12-02-2012, 01:53:14 AM
Power Power is offline
Default Re: Need diagram to wire in a Prestolite TCA 4004 I want to add in the 2 stage regula
Not familiar with that regulator, but that terminology usually means Batt goes to battery, B or B+ is feed, and unmarked is ground.
Old 12-02-2012, 02:09:19 AM
Motorhead's Avatar
I think I figured it out. The TCA 4004 was used jut before the transistorized control and charge system.
Old 12-02-2012, 02:38:48 AM
That is true - obsolete, replaced with later universal model today.
Sooo - how you hooking it up?
Onan 2 to 3 Wire Diagram Daverepair Onan Generators 19 10-22-2014 08:09:14 PM
onan need wire diagram for 4BGEFA11500N saddlechaps Onan Generators 5 01-20-2012 01:28:47 PM
Need simple 12 Wire Generator Wiring Diagram cwbarg Kohler Generators 8 01-25-2010 09:48:20 PM
Voltage regulator wire Arthur Onan Generators 0 11-01-2008 01:11:10 PM
Clinton, wire diagram. Smith Brother Small Air Cooled Gasoline Engines 3 09-07-2005 10:48:16 PM
