Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel Engines
cooling of lister diesel clone
Hi fellows, i sure could use some help on designing a cooling system for a 14hp lister diesel clone...
this thread has 6 replies and has been viewed 782 times
Old 01-04-2004, 10:40 PM
rhud
Default cooling of lister diesel clone
Hi fellows, i sure could use some help on designing a cooling system for a 14hp lister diesel clone that will be used to pull a generator for extended periods of time (days). how do i figure the tank size to cool an engine? i an interested in thermo siphon and a closed tank (so i'm depending on surface area for cooling?). sorry i don't really know enough to ask an intelligent question. any help would be appreciated.
Old 01-05-2004, 04:46 AM
John Hammink
Default Re: cooling of lister diesel clone
Here you have a set up for continue running all day and night. This is a 16 hp engine. I'm afraid that thermo syphon cooling wouldn't work for generating purposes. A second pic can be seen at the link. Hope it's of any help for you.
"Sixm" John
~Second Picture~
Old 01-05-2004, 12:54 PM
dave robertson
hi i used a farmall a rad. and fan on my 1936 10 hp witte diesel runs all day in the sun at show and only get to 150 deg. with water. dave
Old 01-06-2004, 08:30 AM
Harvey Teal
My Witte 14 uses a tractor radiator and fan belt driven from the crankshaft. This setup is rated for 100% duty cycle running a generator. The engine was originally intended to be tank cooled, convection, with a 300 gallon tank. No problems using the radiator, just keep the pipe size as large as you can. I can email instructions from the Witte manual if you like. Harvey
Old 01-06-2004, 09:52 PM
Richard W.
This guy has a lot of info and he will either sell you a lister clone or build you a generator set. Click on engines for more info. I hope this is what you are looking for.
Richard W.
http://www.utterpower.com/
Old 01-07-2004, 09:27 PM
Doug Waggonner
With the Lister copies I deal with I Use the tanks from old hot water heaters, just take off the outter skin and insulation. Or if youd like I can get you a factory radiator for your engine. If I could get my program for my digital camera to work I would just take some pictures of some and send them to you. Doug
Old 01-09-2004, 07:03 PM
rhud
I want to thank everyone that wrote in and also emailed me with information. i've always wanted a "real" engine. but for now i'll live with the reproduction lister. Thank you.
Little Giant Lister clone Dave Lindsay Vintage Diesel Engines 9 10-16-2007 04:57 PM
Opinions of this Lister diesel, please? Daric J Vintage Diesel Engines 20 04-28-2006 05:42 PM
Lister diesel Richard Weich Vintage Diesel Engines 4 06-09-2003 10:05 PM
Lister Diesel gen-set Roger DiRuscio Vintage Diesel Engines 0 02-11-2003 08:19 PM
Lister Diesel engines Pete Daniel Vintage Diesel Engines 3 03-02-2001 02:52 PM
