Onan 191-0324 to 191-1399 conversion
this thread has 27 replies and has been viewed 3178 times
Old 01-18-2013, 03:53:59 PM
dfarr67 dfarr67 is offline
Default Onan 191-0324 to 191-1399 conversion
Hi, in contact with Denso USA and am trying to find a quality non chinese starter that is compatible with the Mits m2t55971 hopefully cheaper. Of course he wants some dimensions and in my searching I did come accross a dimensioned drawing on the mounting for the Mits- but you think I can locate it now......
Old 01-18-2013, 05:21:28 PM
GHanners GHanners is offline
Default Re: 191-0324 to 191-1399 conversion
here is what i have
LESTER 18168 / PIC # 103-073
Type
STARTER
Mfr
MITSUBISHI
Voltage
12
Rotation
CCW
Teeth
10
Str Type
OSGR
Short Note
POWER GENERATOR WITH ONAN ENGINE
INTERCHANGES
ACE TRI-STAR
CM18168N
AIM
SC-0056R
ALLTECH
124-18168
ANDRE NIERMANN
013481
API MARINE
ST1398, ST6003NK
ARROWHEAD
SMT0183
BEPCO
80-18168
BOSTON AUTO
3103-073
COSMOS
90-18168
DIXIE
S-8620
DUBOIS
M900431
EGI
S-18168
ELPAR
012503658
MES MOTORCYCLE & MARINE
18168N
MINNPAR
57-3135
MITSUBISHI
M2T55971
MITSUBISHI SALES
M2T55971
NASTRA
18168
ONAN
191-1399
QUALITY
18168
REMY SMALL MOTOR
RS41175
ROMAINE ELECTRIC
18168N, 18168N-OEM, 41-18168
STRATOLINE
80-18168
TECHNO CVC
IND-2845972
TSA
18168N
WAI
18168N
WAI (OLD)
2-2093-MI
WHATCOM
42421
WILSON HD
91-27-3151
ZORKOS
18168
PARTS BREAKDOWN
ARMATURE
5003-2890
BEARING
5-2603, 5-3203
BRUSH
5403-2706
BRUSH HOLDER
5503-039
SOLENOID CAP
6703-341
APPLICATIONS
ONAN Marine
ENGINES DJC
ENGINES RDJC
ENGINES RDJF
ONAN OPE, Marine & Ag & Industrial
Engines DJC 1979
Engines RDJC 1979
Engines RDJF 1979
ONAN Outdoor Power Equip.
ENGINES DJC
ENGINES RDJC
ENGINES RDJF
The Following User Says Thank You to GHanners For This Post:
Old 01-18-2013, 05:35:29 PM
Thanks, I'm looking for the acad drawing or specifiaction for the bolt holes and nose cone through hole diameter- Denso only has application look up's with no application for Onan. The illustration clearly showed measurements and the one mounting ear that was clocked differently from the 191-0324 180 deg.
Old 01-18-2013, 06:27:53 PM
David C David C is offline
Here is a ND version of the Mitsubishi starter that I have not run across until now. It is from an APIMarine.com online catalog. I would bet that it is not made by ND. I know that it does not help with dimensions, but the seller may be able to shed some light on the subject.
David C.
The Following User Says Thank You to David C For This Post:
Old 01-22-2013, 03:33:37 PM
After a few hours searching- I gave up.
I would like to confirm orientation and rotation of the starter- ring gear is in the front shroud and my contractor's 5DJB-3F manual calls for a 12V 191-0324. I just found a deal for a 18169 10T reman. I think this is correct but have heard of rotation issues before.
Also will the shutter assembly from an mep002a fit this engine?
Old 01-22-2013, 05:53:27 PM
http://www.southernautomotive.com/ca...products_id/95
Shows the military version 24V is clowise rotation
Old 01-22-2013, 06:05:09 PM
Careful-If "the military version" means an MEP-002A, it also mounts on the opposite end of the engine.
Old 01-22-2013, 07:51:36 PM
That's correct- just learning these machines and trying to learn from others mistakes. I do believe the one I'm looking at is correct with ccw rotation vs the military cw rotation.
I am curious as to why so many differences between civilian and military versions ie starter locations, 24v vs 12v, etc I would have figured the more uniform Onan could have kept production- the better.
Old 01-24-2013, 05:47:03 PM
Ordered 2 of these
http://ebay.com/itm/300845104382
The Following User Says Thank You to dfarr67 For This Post:
Old 01-24-2013, 06:08:24 PM
Dave Edmonds's Avatar
Dave Edmonds Dave Edmonds is offline
Smile Re: 191-0324 to 191-1399 conversion
Onan probably would have loved to produce the military units just like the civilian units, but you ain't lived until you work with the military when they want to purchase something! I think they make changes in the designs just to make changes - not to make the units better.
There are also quite a number of Onan's that were built for the phone company - they're pretty much standard units, but most of them have a few "quirks" in their design that make them specifically valuable for their purchaser. One would have to understand the inner workings of the Phone company to understand why the Phone company would want these modifications, but those modifications usually make sense.
Dave Edmonds
Old 01-24-2013, 08:24:28 PM
MBB MBB is offline
dfarr67
I know the original part number for my JB was 191-1398 and it changed to a 191-1399 it was a MITSUBISHI M2T55971. Let me know if they look the same as I would order one also. What is your application?
Old 01-25-2013, 10:30:55 AM
Due to where I live (northern Canada)- I likely won't see these for a month. If you look through the above post on part numbers- this is a Lester part number equivalent with a Onan sticker.
I started just looking for a spare starter but the price of direct drive was $500, and I steer clear from chinese. I also managed to snag the proper mounting plate for $50- although I understand I can drill and tap the old plate to spec. Anybody retrofitted the military shutter asembly unit the civ 5DJB unit- I'm interested in retaining heat but also know whatever is electric on it is 24v.
I think if it's an oe Onan part- they'll all be Mits.
Old 01-25-2013, 11:08:54 AM
Richard L Richard L is offline
Its early,
What exactly do you need? Does your set have a Prestolite, ? 12v ?
And if so are you looking for a Prestolite, or do you want a Mitsubishi???
Re
Rick
Old 01-25-2013, 12:47:43 PM
My unit is 12V and has the original 191-0324 Prestolite. I've commited to the gear reduction on fleabay though.
Old 01-25-2013, 11:29:08 PM
OK Have 3 Prestolites on the shelf.
R
Old 01-29-2013, 06:39:06 PM
MBB MBB is offline
Default Re: Onan 191-0324 to 191-1399 conversion
dfarr67
Thanks for the llink on the starter. Got mine today and its a match. I have not installed it but I will this weekend. I might order another for that price.
Wayne if you didnt order yours yet you should its original not Chinese.
The Following User Says Thank You to MBB For This Post:
Old 01-29-2013, 06:45:57 PM
Thanks for the heads up, unfortunately all were sold by the time I saw this.
Old 01-29-2013, 08:55:47 PM
Shows he still has 3 left.
Old 01-29-2013, 10:03:42 PM
That is what I get for going without sleep. I misinterpreted 4 available and 4 sold to mean all available units had been sold.
Old 01-30-2013, 08:50:32 AM
MBB MBB is offline
GHanners
To update your list for the Onan 191-1398 or 1399 Mitsubishi gear reduction type starter add these part numbers to your list.
Delco Remy DRS0203
EDR 910203
FARCOM 105786
Mitsubishi M2T53481
Mitsubishi M2T55971
Bauer Parts S511296
Application JB 7.5 and as Wayne is looking for one for his RDJC I would say that applies also.
onan conversion 59muskeg Military MEP and Aircraft Gen-Sets 5 03-25-2012 10:32:31 PM
Onan conversion randylee59 Onan Generators 5 02-21-2012 08:39:33 AM
Onan 120 to 240 Vac Conversion Gene Williams Onan Generators 4 01-16-2011 09:56:35 PM
Onan JC 12.5Kw w/ new Propane conversion will not run... Grizzly Hill Onan Generators 6 11-09-2010 09:54:47 PM
Onan 10,000 watt LP Conversion dsgsr Onan Generators 19 01-23-2007 03:36:33 PM
