Onan 3.6kyfa26120g 3600rpm
this thread has 5 replies and has been viewed 824 times
Old 01-19-2013, 11:32:29 AM
saggys saggys is offline
Default Onan 3.6kyfa26120g 3600rpm
Trying to find a suiteable generator for our hunting shack. Wondering the good, the bad on the Onan model 3.6kyfa26120g s/n e973693877. It is 3600rpm rv generator that runs on propane. We have decided to go propane, maybe diesel for our fuel source. I would like something reliable and still able to find parts for.
Old 01-19-2013, 12:01:28 PM
Default Re: Onan 3.6kyfa26120g 3600rpm
Other than being 3600 RPM, it is probably a pretty decent unit. It was built in 5/97. Parts should be easy to come by. From posts here, it seems the starter drive gear & carburetor, are the weak links in the KY units. Running on propane would eliminate most of the carb. troubles. These units have a small oil sump, so there is not much leeway on the oil, check it often & keep it full. I have a KY in my horse trailer & sometimes run it 24 hrs a day for a few days. I shut it down & check oil at least every 12 hours. Electronic engine control boards & most likely electronic voltage regulation. Do not shut it down or run out of fuel while under load, it can get very expensive.
Most of us here at The Stack are fans of the older units, pre 1980, & 1800 RPM. But they come with their own set of quirks.
The Following User Says Thank You to Max Thompson For This Post:
Old 01-19-2013, 12:54:34 PM
len k len k is online now
The Do not shut it down or run out of fuel while under load issue is AC voltage regulator likes to die. On older model gens like Emerald gen that have separate regulator, it's ~$200 - 300 for a new one (flight systems). On yours I think they combined the control board and reg in one more expensive ($800+??) potted board. Keep the slip rings clean or that can kill it too, I think.
Oil ...I think that is the one with no oil pressure or level safty, and it only holds 1qt of oil. Some people with a seized engine say but it was only down a quart of oil (50%).
Old 01-19-2013, 09:55:26 PM
Just got home from a day at the cabin. It was about 28 degrees out and my Kohler powered rv generator (propane fuel) was very hard to get running, it required a shot or two of starting fluid but once running ran great. Plugs and points are new, the stock air intake is missing and it now has a universal air filter, maybe that is a problem? We need something that starts better in the cold weather. I am not to sure what we should be looking for? Thanks for the replies as I need all the advice I can get on various generators.
Old 01-20-2013, 08:59:24 AM
It could be your Kohler would benefit from a “tune up”. Even the good old Onans will cause you to pull your hair when not tuned properly. At 28 degrees, a good 5-30 weight oil may help cold starts. A propane fuel system with a demand regulator presents another source of troubles, are all the fuel system components functioning correctly? Vacuum leaks or regulator vents blocked can make for poor operation of the regulator.
Old 01-20-2013, 11:55:28 AM
Oil is 10w-30w Amsoil synthetic, plugs and points are good. I have never tested the fuel system components. This generator will probably end up a backup as finding parts for it is getting difficult. I think I will start another thread on cold weather starting generators.
Cummins or Onan engine on Onan 20DL4?? fluegas Onan Generators 8 01-11-2013 12:48:02 PM
Onan 2.8 KV need a schematic for an Onan KV Votage regulator uncle Ray Onan Generators 7 08-28-2012 01:30:36 PM
Onan model 15 JC with Onan transfer switch don-mar Onan Generators 4 06-10-2012 08:39:42 AM
Mufler selection to quiet down a 3600RPM Diesel jas67 Generators & Motors General Discussion 10 03-24-2010 09:59:01 AM
Info on going from 3600rpm to 1800rpm SonoraMike Generators & Motors General Discussion 6 03-21-2010 07:50:25 PM
