Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Motors General Discussion > Honda, Yamaha, Kawasaki, Isuszu Generators
Honda, Yamaha, Kawasaki, Isuszu Generators Restoring, maintaining and operating Honda, Yamaha, Kawasaki, Isuszu, and clones.
honda ex 800 no spark
this thread has 3 replies and has been viewed 3803 times
Old 02-09-2013, 04:40:02 PM
yellowlister yellowlister is offline
Default honda ex 800 no spark
i saved this little generator from a pegon shed... smelled something horrable.. after washing the poop off i checked for spark.. nope.. pulled it all apart.. tried disconecting the generator connections to the coil wires still no spark.. pulled the flywheel off it has a exciter and another pickup of some kind behind the flywheel..
i did find the parts, under 30 for both of those... coil is 78..
anyone have any experience with these 800s? i have an exact engine off a edger but the ignition is totally different (guess its not exact).. only has a normal coil..
there isent a way to revive these ignitors is there?
Old 02-09-2013, 04:44:57 PM
Default Re: honda ex 800 no spark
few pics.. hope i can get it going again
Old 02-10-2013, 06:31:13 AM
debe debe is offline
This is the circuit of a Honda EX800 & a circuit for the CDI. You will need to find a suitable Ign coil as this model has the coil built in to the CDI unit. A (EM500 has CDI but uses a seperate IGN coil).
Old 02-15-2013, 03:05:34 PM
robertathonda robertathonda is offline
To resolve a 'no spark' issue, here are the steps from the shop manual:
• Check for fouled, damaged, worn, or improperly gapped spark plug
• Inspect and check operation of engine switch
• Verify high-tension (spark plug) wire isn't open or shorted
• Confirm complete connection from ignition coil to spark plug cap
• Inspect / measure ignition coil
• Inspect pulser coil
• Test C.D.I. unit
-Robert@Honda
Caveat: I work for Honda, but the preceding is my opinion alone.
Honda EB, EV EM EL powerking Honda, Yamaha, Kawasaki, Isuszu Generators 17 05-03-2013 09:57:47 AM
Honda GC trowel Small Air Cooled Gasoline Engines 13 03-07-2011 03:52:53 PM
Honda Problems new points and condenser and still no spark hfd Magnetos, Ignition Coils and Spark Plugs 1 01-10-2011 09:17:19 AM
No spark on Honda E300 generator Ringer Honda, Yamaha, Kawasaki, Isuszu Generators 11 03-08-2010 07:07:32 PM
HONDA STEVE BORLAK Honda, Yamaha, Kawasaki, Isuszu Generators 0 10-31-2004 10:00:45 PM
