onan 7.5 diesel wiring diagram cant read model #
this thread has 4 replies and has been viewed 1259 times
Old 04-25-2013, 09:24:11 PM
inaminutedeere inaminutedeere is offline
Default onan 7.5 diesel wiring diagram cant read model #
Hello,
I have a 3 cyl diesel onan 7.5 kw genset that I just bought that needs a little heip with the wiring on the 12 volt side. all i can read of the model # is 5okofj the o's could be d's serial # is L943301744 spec # 277980 or maybe a D on the end hard to tell. any help would be great!! thanks
Old 04-25-2013, 09:29:16 PM
Kpack Kpack is offline
Default Re: onan 7.5 diesel wiring diagram cant read model #
See if you can get these guys some pictures it will help them identify it.
Old 04-25-2013, 11:09:43 PM
GHanners GHanners is offline
post or send me your email and i'll send you what i have
looks like a 1994 model 3 cyl 7.5 DKD
I have a 7.5DJDFJ spec 27798C but it's 1988 model
The Following 4 Users Say Thank You to GHanners For This Post:
Old 04-26-2013, 02:59:30 PM
manuals sent
how many hrs are on it ?
found some voltage codes for these units
B-120/240 volt, 60hz 1 phase 3 wire
C-120/208 volt, 60hz 3 phase 4 wire
D-120/240 volt, 60hz 3 phase 4 wire
G-277/480 volt, 60hz 3 phase 4 wire
J-120/240 volt, 60hz 1 phase 4 wire
L- Reconnectible, 60hz Broad range
P-120/240 volt, 50hz 1 phase 4 wire
Z-Reconnectible, 50hz Broad range
R- Special (spec number req'd to Identify)
The Following 2 Users Say Thank You to GHanners For This Post:
Old 04-27-2013, 09:15:29 AM
Got the manuals. Thanks a bunch! it has 9000 hrs on it, been rebuilt on both ends, runs great but the 12 v wiring has been all hacked up. want to fix it so all the safetys work and so on. Thanks again for all your help. if I run into a snag I will be begging for more info.
T Model Coil Wiring Diagram John W Magnetos, Ignition Coils and Spark Plugs 2 04-20-2013 01:08:02 PM
Onan wiring diagram needed for model 4.5PG-3P/1B dynabruce Onan Generators 1 12-09-2012 10:06:38 PM
Onan Model 6.0 CCKB-1R Wiring Diagram + N5OE Onan Generators 4 11-06-2012 10:29:36 PM
Moline Universal model D wiring diagram William Engelmann Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 02-19-2012 09:21:38 AM
Model # 4DKCFA23006B wiring diagram needed porschemann Onan Generators 5 01-09-2011 08:10:21 PM
