need info for briggs NR6
this thread has 5 replies and has been viewed 1171 times
Old 05-08-2013, 03:35:44 AM
Mike in CA Mike in CA is offline
Default need info for briggs NR6
I almost have this engine finished but I need info on the governor setup before I can finish it. This engine was missing the carb and the air vane governor was broken when I got it. Will the governor from another model of briggs work on this engine? Also is there a way to get the correct throttle linkage for this engine?
Its a 1944 NR6 if that helps.
Mike in CA
Old 05-08-2013, 05:15:49 AM
Chris Page
Default Re: need info for briggs NR6
There should be a spring that goes from the governor to the throttle, your engine was built in feburary of 1944.
Old 05-08-2013, 09:05:15 AM
Bowtiebutler956 Bowtiebutler956 is offline
Images: 68
Very nice NR6. Here are a few pics of the carburetor linkage, showing the placement of the springs. There is also a pic of the link the goes from the air vane governor to the throttle link on the carb. The air vane gov off any model N will work for you with the exception of the NS, as it had a suction carb.
Matt
It wouldn't let me post a pic of the link, as I had already used this pic in another thread. I'l try to get you some more pics when I get home from work.
The Following User Says Thank You to Bowtiebutler956 For This Post:
Old 05-09-2013, 01:15:44 AM
Thanks for the pic's. It looks like I am missing the thumb wheel adjuster and threaded shaft that attaches to the mag plate also. Are the springs hard to find?
Old 05-10-2013, 10:49:19 PM
Images: 68
The thumb wheel was only used on engines that didn't have a throttle cable going to them, and were set up to always run the same speed. I have about 20 model N's, and less than half have the thum screw setup. The spring part numbers are Briggs #26267, and #26393. They pop up on ebay now, and then, but if you want to find them quickly, give Will Woodard a call. (540-273-7541). He has an ebay store called willswhatnots, but he only list a few items at a time. He has a huge inventory of vintage Briggs parts, and I've bought these springs from him several times. You can call him any time before about 8pm. He's a friendly guy, and he'll have just about anything you need for your old Briggs. Tell him Matt (bowtiebutler) sent you. I still don't have an NR6, but I'll get one some day. I do have 3 NPR6's, and all kinds of N's, NP's, NS's etc. That a great engine you have there.
Matt
Old 05-14-2013, 05:38:09 AM
@ bowtiebutler956
PM sent
Info on Briggs 12.7 hp? Houston Small Air Cooled Gasoline Engines 1 04-06-2010 06:18:27 PM
Help with Briggs info akretowicz Small Air Cooled Gasoline Engines 4 05-22-2009 09:46:25 PM
Need Info on Briggs Ken Uplinger Small Air Cooled Gasoline Engines 12 11-02-2008 12:50:04 PM
Briggs info please Ihorse Small Air Cooled Gasoline Engines 2 11-24-2007 10:02:51 PM
Briggs HP info Vernon Antique Engine Archives 1 04-18-2003 11:16:42 AM
