Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Horse Drawn Equipment
Horse Drawn Equipment Old iron designed for the purpose of hitching up to a horse or a team. This old iron machinery may be used or demonstrated while hooked to an old iron tractor too.
Antique wooden manure spreader - make / model?
this thread has 12 replies and has been viewed 8604 times
Old 06-28-2013, 02:36:45 AM
shiplemw shiplemw is offline
Default Antique wooden manure spreader - make / model?
Hello,
I'm looking for some information on a large manure spreader that was on my property when I bought it. It's about 6' wide and atleast 12' long. I swear I can see some John Deere lettering and it reminds me of a Model E manure spreader but.. I'm not an expert. I'm trying to figure out if I should keep it, sell it (if I could) or what. Can anyone help me out?
The Following User Says Thank You to shiplemw For This Post:
Old 06-28-2013, 10:31:07 AM
MikeR. MikeR. is offline
Default Re: Antique wooden manure spreader - make / model?
It does look like a model E John Deere. The casting number on the hubs should be JD 2403(not 100% sure) if its a E. Made in the 20's and 30's. Check the numbers on the hubs. This is what is needed to get the year and model because they didn't have serial numbers.
---------- Post added at 10:31 AM ---------- Previous post was at 10:23 AM ----------
Where in Michigan are you located.
The Following User Says Thank You to MikeR. For This Post:
Old 06-28-2013, 10:41:52 AM
Their is a Chance it could be a Massey Harris or IH aswell but it looks more like John Deere E as Mike said and it also looks to be fairly compleat too.I would be interested in seeing the wheels were it has been touching the ground if it has sat long enough the wheels might have rotted as the last one i seen in the same shape the wheels had rotted out from sitting too Long and when they are like that all their good for is a lawn orniment unless you can find another set of wheels for it.John
Old 06-28-2013, 10:57:26 PM
Thanks for the reply. I'll take a look at the hubs tomorrow and see what information they have. Oh yeah, near Lansing.
---------- Post added at 10:57 PM ---------- Previous post was at 10:50 PM ----------
Originally Posted by casertractor View Post
...I would be interested in seeing the wheels were it has been touching the ground..
I'll roll it forward and see what they look like.
Old 06-29-2013, 01:28:13 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Definitely a John Deere, we have its twin here that we still use. Deere was proud of that design with the main beater mounted on the main axle, one of their big advertising points. I just replace the wood when it gets bad and the rest isn't too difficult to keep working. F.J.W.
Old 06-29-2013, 01:41:33 PM
Avery22x36 Avery22x36 is offline
Better keep it, they only get rarer! Looks like an easy fixer upper. The John Deere's I have seen didn't bust out the hubs like the International ones did.
The Following User Says Thank You to Avery22x36 For This Post:
Old 06-30-2013, 11:25:33 AM
I was able to look at the hubs.
Front hubs - JD 2408
Rear hubs - 362780 (I think, difficult to read)
So I am curious how one goes about restoring something like this. The thought of turning it back into a working piece of machinery intrigues me. Are there any good guides for restoring older equipment or is it a learn as you go experience?
Old 06-30-2013, 09:06:24 PM
Pictures of the wheels after I rolled it forward several feet.
Old 07-01-2013, 11:51:20 PM
Those Wheels look to be savable just some surface rust all they need is a clean up.if they had been left any longer i would say they would have rusted right thru.John
Old 07-09-2013, 07:41:43 PM
Old Kansas Old Kansas is offline
I restored a New Idea that was in really bad shape. It took alot of time and trial & error, but came out OK. I am sure it would work but I am not going to get it dirty.
The Following User Says Thank You to Old Kansas For This Post:
Old 07-11-2013, 01:13:08 PM
Old Kansas - Did you use modern fasteners or did you find square headed fasteners / bolts?
Old 07-11-2013, 03:36:28 PM
Square head bolts can be found at Fasenall.
Old 07-11-2013, 11:47:00 PM
I used modern fasteners where the wood was fasten to the angle irons. Mine had rivets, there was no way I was going back with them. Alot of the the square head bolts, I was able to save.
IHC #4 Manure spreader bearhunter01 Horse Drawn Equipment 15 05-06-2013 12:09:55 AM
IH Manure spreader Bill Luepke Farm + Industrial Antiques and Collectibles 2 11-21-2012 01:58:30 PM
Manure Spreader ID? 71ford100 Horse Drawn Equipment 5 05-24-2012 10:22:14 PM
Need help with ih 100 manure spreader Lvolling Farm + Industrial Antiques and Collectibles 0 12-29-2010 03:34:05 PM
Manure Spreader Identification Larry K Horse Drawn Equipment 6 03-07-2010 10:22:54 PM
