Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
Multi-Cylinder Stationary Engines and Power Units Waukesha, Buda, Climax, LeRoi and others.
6602 Contenental engine
this thread has 2 replies and has been viewed 1251 times
Old 07-11-2013, 06:55:47 AM
Ben Snider Ben Snider is offline
Default 6602 Contenental engine
I have a big 6602 continental gas engine in a 5 ton m62 army truck the engine starts fine and idles fine when i push the accelerator the engine bogs down and wont rev up also it will back fire a lot when doing this i have had the carb all apart and it seems fine it is all set up as far as the manual states any ideas would be greatly appreciated not sure what to do this engine ran great when we got it without any problems but now this has occured
Old 07-11-2013, 12:43:39 PM
mikebohman mikebohman is offline
Default Re: 6602 Contenental engine
Sure sounds like a fuel supply problem. It gets enough gasoline to idle, but not to pull a load. Filter plugged, bad transfer pump, wood chip or rag over intake in fuel tank, any number of things that would block the supply of fuel.
Old 07-12-2013, 01:51:10 AM
Concur sounds like classic case of starving for fuel...
Kill engine, try pouring a bit right into carb (assuming downdraft carb!), let set for 15 secs or so...will start as if flooded (which it will be) but then should rev up until fuel you poured in is burned...
military contenental twin Andrew Mackey Small Air Cooled Gasoline Engines 4 10-17-2005 02:16:22 PM
