Steam Engines
Cabover Phoenix Log Hauler (Circa 1922)
this thread has 1 replies and has been viewed 1609 times
Old 08-08-2013, 10:41:00 PM
tharper tharper is offline
Photo Cabover Phoenix Log Hauler (Circa 1922)
Hello folks,
While working on some research I stumbled upon this amazing machine in the January 7, 1922 issue of "American Lumberman"
Its well known that Phoenix produced steam log haulers based on the Nov. 1900 Lombard patent which they were licensed to use. We also know that around 1914-15 they attempted to market a gasoline version which was later offered in modified form by Allis Chalmers.
What I did not know is that Phoenix had tried to produce a advanced steam design as late as 1922!
Here are the specs (note the use of compound engines, condensers and an advanced boiler design.)
Source: The Phoenix Road Locomotive, American Lumberman
January 7, 1922, pp 68 & 69
Boiler pressure: 400 psi
Steam chest pressure:300 psi @ 25% cutoff (super heated)
Boiler: Drumless sectional water-tube boiler designed by W.H. Winslow (Winslow Bro. Co. Chicago, IL.)
Burner: Blast type (oil, low grade distillates)
Condensers: Under normal operating conditions the water lose per gallon is equal to the fuel burned.
Weight: 8-1/2 tons
Capacity: (deck load) 5 tons
Drawbar pull:(normal) 2,500 lbs @ 6 mph
Drawbar pull: (Maximum) 5,000 lbs @ 6 mph
Wheel base: 10’-6”
Engines:(2) 3-1/2x7”x5” (compound)
Brake horsepower: 60 hp @ 25% cutoff
The article optimistically states: “Orders are now being tentatively accepted for these road locomotive – deliveries scheduled for the spring of 1922”
Apparently like the gasoline tractor this machine used a track design by C. L. Tolles (Pat. 1106595, Nov. 1, 1912) that is based on the Nov. 9, 1900 Lombard patent as previously used by Phoenix.
W.H. Winslow patented quite a number of boiler designs. Since the article stated it was a sectional water-tube design that had 10 years and $150,000.00 of development behind it I assumed it to based on this his May 1921 patent.
Makes you wonder if the prototype was ever completed and if so how many others were produced.
Best regards,
Terry
Old 08-12-2013, 07:42:47 AM
Marv in Minn's Avatar
Marv in Minn Marv in Minn is offline
Default Re: CABOVER PHOENIX LOG HAULER (Circa 1922)
as a follow up history, there is
interesting reading about the Linn tractor at
http://en.wikipedia.org/wiki/Linn_tractor
The Following User Says Thank You to Marv in Minn For This Post:
Phoenix log hauler operator Paul E Steam Stationary Engines, Traction Engines, Steam Boats 20 11-06-2009 12:55:49 AM
Phoenix Log Hauler Grape Steam Stationary Engines, Traction Engines, Steam Boats 2 10-25-2009 09:15:43 PM
1/6 scale PHOENIX LOG HAULER Ackman Steam Stationary Engines, Traction Engines, Steam Boats 16 09-19-2009 06:27:45 PM
Phoenix Steam Hauler photos Dave Preuhs Steam Stationary Engines, Traction Engines, Steam Boats 27 06-26-2008 04:02:51 PM
Phoenix Steam Hauler pics Craig A Steam Stationary Engines, Traction Engines, Steam Boats 7 04-28-2005 08:02:03 AM
