Wisconsin Engines
VG4D Firing order and cylinder config.
this thread has 10 replies and has been viewed 4740 times
Old 09-01-2013, 05:31:38 PM
dbarn6 dbarn6 is offline
Default VG4D Firing order and cylinder config.
I need help with a vg4d wisconsin engine mounted on a Case 3300 B series skid steer loader. I want to make sure I have the firing order correct. What is the cylinder number configuration? Firing order? and distributor rotation?
Old 09-01-2013, 07:30:56 PM
Phil P Phil P is offline
Default Re: VG4D Firing order and cylinder config.
Hi
#1 is closest to the flywheel #4 is furthest from the fly wheel.
The firing order is the same as any inline 4 cylinder engine.
Phil P
Old 09-01-2013, 10:59:39 PM
This is a V 4 cylinder.
Old 09-02-2013, 07:41:53 AM
That is correct you have a VG4D.
The crank shaft in the VH4 and the VG4 is constructed so it works like an inline 4 cylinder engine.
You will find #1 cylinder the one closest to the flywheel and #4 cylinder the on closest to the back of the engine and on the other side from the #1 cylinder will make TDC at the same time just like an inline 4 cylinder engine.
The firing order is the same as any 4 cylinder inline engine 1-3-4-2.
The VE4 and VF4 were early engines had a crankshaft that did not cause any 2 pistons to make TDC at the same time. These 2 engines are different but still use the same firing order but a much different timing sequence because the rotation between 2 piston reaching TDC was close together and the other 2 were farther apart. Different timing sequence but still the same order 1-3-4-2.
Phil P
The Following User Says Thank You to Phil P For This Post:
Old 09-02-2013, 06:17:43 PM
Thank you for the explanation,, I just didn't understand. Now is number one cylinder on the left or right standing on the fly wheel end looking toward the engine. Sorry i just don't know.
Old 09-02-2013, 08:15:26 PM
Hi
The one closest to the flywheel is #1. It has been over 30 years since I worked on one of the Wisconsin’s. If you stand in front of the engine facing the flywheel #1 is on your left and closest to you. #4 is on your right and farthest from you.
Phil P
Old 09-02-2013, 10:14:43 PM
moteurdelco moteurdelco is offline
like phil said;1 at left;; 2 and 4 at right.
distributor rotation can be seen in removing cap.
Old 09-03-2013, 08:50:24 AM
Heins Heins is offline
The # of the cylinders are stamped on the sheet metal below the spark plugs.
Old 09-03-2013, 12:29:19 PM
'This engine is in a skid loader. You probably can’t see the sheet metal and provided some one hasn’t changed the sheet metal.
Phil P
Old 09-03-2013, 07:46:58 PM
Can you see the spark plugs?
Old 09-03-2013, 08:01:09 PM
On some of the skid loaders no you can’t see the spark plugs without some disassembly of the machine. And thin just like the guy with the VE & VF that had a question about where the flywheel key was located. He had a VH with the wrong sheet metal on it. LOL
I don’t normally fool with firing orders I just remove all the spark plugs put my finger over a spark plug hole and turn the engine until I feel compression then turn it until one of the wires sparks. That wire goes on the plug that is at TDC.
I have done this on engines with as many as 32 spark plugs.
Phil P
Wisconsin SU 4x5 Firing order 911yogi Antique Autos and Trucks 9 03-09-2015 01:49:51 AM
Wisconsin V4 firing order PMilten Wisconsin Engines 1 03-13-2008 04:57:05 PM
firing order doc Antique Engine Archives 2 10-11-2004 10:15:08 PM
Kohler 4 cylinder firing order Ken Antique Engine Archives 1 03-11-2004 02:47:07 PM
Firing order Tom Johson Antique Engine Archives 2 02-13-2000 07:59:13 PM
