Scale Model Engineering Steam, gas and hot air model engines, tractors and accessories. Machining and milling castings.
Ford 300 I six model engine
this thread has 56 replies and has been viewed 7857 times
Old 12-17-2013, 07:01:42 PM
gbritnell gbritnell is offline
Default Re: Ford 300 I six model engine
The 2 remaining pieces are the fuel pump and oil filter.
gbritnell
The Following 6 Users Say Thank You to gbritnell For This Post:
Old 12-17-2013, 07:05:04 PM
The last picture is just an overall 3/4 shot showing most of the small parts attached.
gbritnell
The Following 7 Users Say Thank You to gbritnell For This Post:
  #43
Old 12-17-2013, 09:53:33 PM
chrsbrbnk chrsbrbnk is offline
pretty much awe struck, looks fantastic!
Is there some sorta break in routine ?
The Following User Says Thank You to chrsbrbnk For This Post:
  #44
Old 12-29-2013, 03:38:04 PM
Gentlemen,
Time for an update on the engine. It's down to making small parts and finishing up the intake manifold and head by plugging and contouring. To keep with the overall look of the engine I made a starter and alternator along with the mounting brackets. The alternator will also be used to adjust the fan belt to run the water pump. The starter mounting area took a little work to get the starter in approximately the right position because of the thickness of the bellhousing flange on the back of the block.
gbritnell
The Following 5 Users Say Thank You to gbritnell For This Post:
  #45
Old 12-29-2013, 03:41:24 PM
Here's the final pictures of the front of the engine with the alternator installed.
gbritnell
  #46
Old 01-04-2014, 11:02:45 AM
Gentlemen,
I have to take a break in the build for awhile as I have a portrait commission to complete so here's the latest update.
I made up the fan for the engine. This required making a set of stamping dies to form the stiffening bead that runs down the center of the blades. I made this from an old aluminum fixture plate. I cut groove in the lower plate to hold pieces of .062 drill rod to form the beading.
gbritnell
The Following 2 Users Say Thank You to gbritnell For This Post:
  #47
Old 01-04-2014, 11:05:31 AM
The beading went fine but when I got to the twisting of the blades I found that I had to allow more space because the blades wouldn't sit flat against each other.
gbritnell
The Following 3 Users Say Thank You to gbritnell For This Post:
  #48
Old 01-04-2014, 11:11:09 AM
I also found that when I made up the first set of blades they were a little too short and that I didn't have any way of holding them to put the bolt holes.
I modified the beading fixture to hold longer blades and I also drilled them in the same fixture while they were located and flat.
To twist the blades I made up 2 sets of clamping blocks. One set to clamp the blades and another to clamp onto the blade a fixed distance away to allow room for the proper amount of twist.
  #49
Old 01-04-2014, 11:14:30 AM
The second set came out to my liking so I put the proper radii on the ends of the blades and also the small bend at the end. I'm assuming this is for some aerodynamic condition on the full sized blades.
The final picture shows the completed blades mounted on the water pump pulley.
gbritnell
  #50
Old 01-04-2014, 01:05:07 PM
jamesk815 jamesk815 is offline
Images: 10
gbritnell
I have been admiring your model engine's for a long time. I am a friend of Bob Nawas, we sat across from you over in Ohio at Debolts show. To the people that have never seen the models in person , they run as good as they look! I would like to see some pictures of your shop sometime.
jamesk815.
Old 01-04-2014, 02:30:21 PM
Hi James,
Thanks for the accolades.
Here's a link to a short video of my shop. The only thing that's changed is I have a new mill. The old round column Enco served it's masterly duty for many years but in the end I just got tired of having to pick up setting every time I moved the head.
http://youtu.be/K7_O2jPpmEg
New mill.
Old 01-04-2014, 05:55:51 PM
Images: 10
gbritnell
Thanks for the tour of your shop, see you at NAMES. in April.
jamesk815
Old 01-04-2014, 08:01:38 PM
Gil Garceau Gil Garceau is offline
Thanks for the nice tour, George.
Now I know where your magic is executed.
The latest pictures of your Ford 300 6 look just plain awesome!
Thank you for sharing it and Happy new Year!
Gil
My youtube channel: http://www.youtube.com/user/reddrryder/videos
Old 05-09-2014, 02:04:45 PM
Gentlemen,
The engine is running. Having been away for almost 5 weeks I was in a rush to get it running for the NAMES show but that didn't happen. My apologies to those fellows that came to the show to see it running. This is the second running. I fired it up earlier in the week but had a few adjustment and modifications to make.
It seems like the air bleed hole in the carb needs to be a little bigger because it takes too much adjustment on the main needle to go from idle to high speed.
So far everything seems to be working well. It looks like it will need a different seal in the timing cover because it leaks a little.
Here's the link to the Youtube video.
http://youtu.be/tdrEHY3uqqs
gbritnell
  #55
Old 05-09-2014, 03:09:14 PM
Images: 10
George
Fantastic! I am looking forward to seeing it run at Debolts show this fall. Thanks for the prints you sent me , they well work great when I start on the Holt
Jim Gehringer
Old 05-09-2014, 07:01:50 PM
Capt...John Capt...John is offline
Originally Posted by gbritnell View Post
I have just completed the distributor. It has a Hall transistor triggered by one magnet inside. The Hall is controlled by a timing disc with 6 windows milled around the outside. The outside diameter is 1.05 inches.
gbritnell
This type of ignition would work on a Holt 4 cyl like I have I think. Only have 4 windows for the timing disc? What do you think? Thanks John
Old 05-09-2014, 09:21:37 PM
Hi John,
Sure it will work on a 4 cylinder engine. I even have it on my V-8 and it works great. There seems to be enough coil saturation even at high rpm's because the V-8 will spin 7,800 rpm.
gbritnell
Engine identification (Ford Model F) davehj Antique Autos and Trucks 20 10-19-2010 12:18:48 PM
T model Ford "IPCO" engine Inter Bloke Antique Autos and Trucks 3 09-27-2010 12:21:12 PM
Open Engine - Ford Model A B Kedrowski YouTube Old Iron Videos 6 08-07-2010 12:45:51 PM
Ford model A engine Mark Mohney Antique Autos and Trucks 4 06-30-2009 04:02:49 PM
Ford model B engine Jim Arras Antique Autos and Trucks 1 05-18-2009 12:27:55 AM
