John Deere tractor L or LA
I have acquired a John Deere Model L or LA tractor that needs engine work. What is the difference...
this thread has 2 replies and has been viewed 1051 times
Old 07-20-2000, 07:36 AM
bob s
Default John Deere tractor L or LA
I have acquired a John Deere Model L or LA tractor that needs engine work. What is the difference between a Model L or LA and how do I find what model it really is? Thanks in advance.
Old 07-20-2000, 12:27 PM
Ron Oberloh
Default Re: John Deere tractor
Just for starters the L has hollow frame tubes and the LA has solid. The wheels are different. The LA has a big cast center with the rim bolted to it and the L is a pressed wheel more like a standard automobile wheel. Also the L has I believe 22 inch tires on the rear and the LA has 24 inch ones. There are thing like the seat is different but I believe this should be enough info so you can determine what you have.
Ron
Old 07-20-2000, 01:34 PM
larry@yahoo.com
There was a LI model too. Looked like la but had no belt pullys and were yellow.
110 john deere lawn tractor Steve Kreiner Antique Gas Engine Discussion 2 04-28-2007 08:51 PM
John Deere Unstyled L Tractor Mike in NC Antique Tractor Talk 6 06-10-2005 10:12 AM
John Deere E on a garden tractor John Klingler Antique Engine Archives 4 09-09-2003 12:18 AM
want john deere tractor mag mark K Antique Engine Archives 0 07-29-2003 10:48 PM
[IMG] code is Off
