Trailer wiring schematicI am rewiring a trailer I am redecking. Does anyone have a schematic I can refer to or URL for...this thread has 7 replies and has been viewed 23623 times
I am rewiring a trailer I am redecking. Does anyone have a schematic I can refer to or URL for same? While I have it apart I might as well clean up years of cob-jobs. BTW it has electric brakes on one of two axles. Made by Big Tex. Has breakaway switch. Looks like there are 4-5 wires to the 7 pin plug.
If my memory serves me correct the Brown and Yellow wires are for the left and right turn signels. Can't remember which one is which. Green is ground for sure. And i think the white is the stop or brake lights. and one for your brakes. Hope that helps some.
Check out www.etrailer.com/faq/wiring.asp
Brown- Tail & Running lights, Yellow- Left turn, Green- Right turn, White- ground, Blue- Brakes, orange or red- Aux., Black- 12volt |
Andrew- Thanks; I can find the pinout of the plug... I am looking for a picture of how all the lights connect and how the breakaway switch is wired in. I am replacing ALL the wires on it from the plug back.
Paul, Here is another site. You should find it in the technical section. Lights, brakes, break-away, etc.
http://www.championtrailers.com/ |
Just a little hint on the use of the scotchlock connectors. These are normally blue and allow you to connect a single wire to a wire that is passing by. say a clearence light.. for years I used them and had problems with salt eating away at the connection.. Until I started useing a little dab of RTV silicone in the scotchlock before I installed the wires and clamped them shut with the latch.. This has helped 100% to make it a quick and easy water tight connection.. hope this helps.. Randy Hart Ohio
The breakaway switch is wired directly between the battery and the brakes. Thisis so that if the wire cable to the breakaway switch is pulled hard enough to activate the switch the brakes recieve the full 12 volts from the battery thus locking up your brakes. The brakes will remain locked up untill you manualy deactivate the breakaway switch by replacing the plastic wedge between the terminals in the switch. Chuck in sunny Central Oregon
| 7cm21-rv Wiring Schematic And Manual | mdfiore | Kohler Generators | 6 | 06-27-2008 03:33 AM |
| Where can I get a basic Wiring diagram or schematic? | scruffdawg | Garden Tractors / Mowers / Scooters | 0 | 03-07-2008 01:15 PM |
| wiring schematic for 12.5JC 3CR31/13S nat.gas | Sam Mayberry | Onan Generators | 1 | 02-19-2005 12:15 AM |
| Onan 5L and 10L Wiring Schematic/operators manuals? | Keith Kessler | Onan Generators | 0 | 01-16-2005 12:12 AM |
| wiring schematic 6 volt | Nelson Johnson | Generators & Motors General Discussion | 1 | 10-11-2003 05:09 PM |
