Paint Shop
Rustoleum Hard Hat
Has anyone ever used the Rustoleum HardHat Paint? I have been told it is a good one to use in our...
this thread has 8 replies and has been viewed 2270 times
Old 01-09-2002, 02:34 PM
JERRY
Default Rustoleum Hard Hat
Has anyone ever used the Rustoleum HardHat Paint? I have been told it is a good one to use in our Hobby>
Old 01-10-2002, 06:23 AM
Default Re: Rustoleum Hard Hat
Jerry: Never heard of Rustoleum Hard hat. Only can find Rustoleum Professional in "LIMITED" colors at the depot. I like Professional because it dries quickly and is tougher that regular Rustoleum. I get tired of these stores changing brands and then you have to start looking all over again. Used to use a lot of the Acrylic Enamel, but can't find it around any more. Guess I'll have to try the Pep Boys brand that has been suggested previously.
Paul in NJ
Old 01-10-2002, 10:16 AM
JERRY
Paul I have only been able to find the Hard Hat Brand at Industrial Supply Houses like Graingers. I did however send an E Mail to Rustoleum and asked them which of their finishes they would suggest for Gas Engines. At this point they have not responded. When they do I will post the results.You may want to check out their Web Site also WWW.rustoleum.com
http://www.rustoleum.com
Old 01-14-2002, 05:12 AM
Jerry: Thanks for the Rustoleum WEB site. I'll just have to look around and find a place locally that has what I need.
"THANK's"
Paul in NJ
Old 01-15-2002, 06:00 PM
chase
Default Rust-Oleum Response
You probably should be using a two-component product such as a polyurethane. We have a direct-to-metal coating, the 9800 Urethane Mastic. Check out the Industrial side of our site for the Technical Data Sheet.
Straight From The Horses Mouth I also e-mailed rustoleum and thats what they sed..
Chase
Old 01-16-2002, 04:00 PM
Ken Fall
Default Re: Rust-Oleum Response
I USED "HARD HAT" SPRAY PAINT TO PAINT MY ALAMO SAFETY BLUE ALMOST EXACT MATCH TO THE PAINT THAT WAS ON MY ALAMO IN THE HIDDEN SPOTS. ITS BEEN 5 YEARS NOW AND IT IS STILL HOLDING UP VERY WELL. I LIKE TO RUN MY ENGINES AND THEY GET VERY GREASY. I AM ALWAYS CLEANING THEM AND STILL THE PAINT LOOKS GOOD. KEN
Old 01-16-2002, 06:34 PM
JERRY
Hi all I finally got a response fro Rustoleum and they have recommended "RUST-O-THANE" they also shared a phone number 1-800-481-4785 and a Web site www.rustoleum.com/ibg/literature/Rust-O-Thane/rustothane4.htm
Old 01-17-2002, 10:40 PM
Ted Best
Just used Hard Hat for the first time on a grist mill I'm restoring and am quite pleased with it. A friend of mine recommended it and it dries quick and is a good hard finish with high gloss. Home Depot here in Florida carries it.
Old 09-12-2005, 02:53 PM
JBoogie's Avatar
JBoogie JBoogie is offline
Images: 127
i've been using the "hard-hat" for about five years for painting machinery (lathes, mills) and engines and haven't had a single problem. you can get a real nice shiney paint job if you sand with some 600 grit, allowing about a week between sanding and re-applying coats. i did this on the shroud of an old model y and it looks like a GM factory paint job!!!! good luck
Rustoleum & humidity Kevin Marshall Paint Shop 5 07-21-2006 06:15 PM
Fairbanks Morse Green in Rustoleum Joe LeBlanc Antique Engine Archives 5 09-06-2002 11:17 PM
does Rustoleum still make...... NICK Paint Shop 1 03-18-2002 07:58 PM
Rustoleum and Gas Tank Rich Bierly Antique Engine Archives 3 08-05-2000 12:04 AM
Re: Rustoleum and Gas Tank Glenn Karch Antique Engine Archives 0 08-02-2000 11:36 PM
